LED Fuel Gauge Gas Cap : V-Twin Forum: Harley Davidson Forums
Old 11-29-2008, 09:58 AM   #1 (permalink)
paul_bullerin wants to know Dino or Syn?
My HD LED fuel gas crapped out after 5 months. Turned the ignition on one day and no LED lights. Dealer checked the gas cap and said it has power in and power out. Could sending unit be the problem? I see from the forum that these LED fuel gauges don't seem to have much of a service life. A $150 I feel the motor company ripped me off. Any comments are appreciated.
paul_bullerin is offline   Reply With Quote Quick reply to this message
Old 11-29-2008, 10:20 AM   #2 (permalink)
Buddha4's Avatar
Buddha4 wants to know Dino or Syn?
The first one I had was replaced by the dealer since it was less than 30 days. The current one usually has the 1st two leds go out but it periodic so I know the LEDS still work. Most likely a bad connection within the cap itself. Since it only affect thes the 3/4 to 1 full portion then I'll deal with it.
IBA 31086
Buddha4 is offline   Reply With Quote Quick reply to this message
Old 11-29-2008, 11:45 AM   #3 (permalink)
Coolmaker's Avatar
Coolmaker wants to know Dino or Syn?
Moisture gets in them and causes havoc. When you wash the bike put a piece of saran wrap over the top of it until you are done. It will stop most of the problem. The other thing I do once in awhile is to release the gauge, pick it up partway out of the tank and let it air dry. It will go back to work then.
Coolmaker is offline   Reply With Quote Quick reply to this message
Old 11-29-2008, 03:53 PM   #4 (permalink)
sportchuck wants to know Dino or Syn?
I read somewhere about using dialectric grease to solve this problem.
sportchuck is offline   Reply With Quote Quick reply to this message
Old 11-29-2008, 11:20 PM   #5 (permalink)
Coolmaker's Avatar
It is not the connector that causes the problem, it is the moisture getting inside the LED gauge that does it....
