Originally Posted by flstc_geek
I still think that out of 5 gal, at least 4.5 of it should be usable.
I'd be almost certain that 4.5 is useable... but here's the problem.
Depending on HOW YOU DROVE FOR THAT TANK OF GAS, you're mileage is going to differ, so when you hit that 4.5 gallons point, the odometer reading might not be the same. Comprende?
Example... if you did lots of in-town-driving, you might have used up 4.5 gallons at 210 miles. if you did lots of 55mph cruising on the highway, it might not occur until 240 miles. Understand, these are ballpark numbers, just trying to give you an idea.
Basically... going by the gauge is fairly fruitless with these MoCo gauges. So you just have to decide what your personal comfort level is with the odometer method.
An aside... I don't blame the MoCo for their inaccurate gauges... primarily it's a function of the oddly shaped tank. If the tank were a nice "rectangle" (such as most automobile gas tanks)... the float would travel up and down such that halfway up, it's half full, etc.
With these tear-drop shaped tanks... it's a much tougher "target"
