Fatboy oil change : V-Twin Forum: Harley Davidson Forums
Old 05-13-2008, 07:02 PM   #1 (permalink)
R19KBE is on a distinguished road
Fatboy oil change
When changing the oil on a fatboy how do you get the oil out of the tank
R19KBE is offline   Reply With Quote
Old 05-13-2008, 07:09 PM   #2 (permalink)
20538 will become famous soon enough
the drain plug is under the bike, between and above the rear shocks. it's a blind mans trick but you'll get use to it.
20538 is offline   Reply With Quote
Old 05-13-2008, 07:13 PM   #3 (permalink)
oil
Thanks for the info
Old 05-13-2008, 07:45 PM   #4 (permalink)
ChopperDude is on a distinguished road
Ummmm... that's the TRANSMISSION drain plug that you described!!
The engine oil drain plug (for Twin Cams) is at the frame, right side right at the back of the frame rail. A hose goes from the back of the oil tank down the right side, adjacent to the swingarm, down to a "fitting", with drain plug.
ChopperDude
ChopperDude is offline   Reply With Quote
Old 05-14-2008, 07:30 AM   #5 (permalink)
GrampsWyatt's Avatar
GrampsWyatt is on a distinguished road
The dude is right. On the frame rail. Above shocks is trans.
2007 FLSTF
Filter with Red Oil
2-1 pipe
Some Other Stuff, air in tires, black seat, etc.....
GrampsWyatt is offline   Reply With Quote
Old 05-14-2008, 05:00 PM   #6 (permalink)
ah chit, sorry dude. going by memory of my last bike but apparently a bad memory.
Old 05-14-2008, 09:25 PM   #7 (permalink)
sportchuck is on a distinguished road
Don't mean to hijack this thread but how many of you folks replace all the o-ring and gakets every time you do the service?
sportchuck is offline   Reply With Quote
Old 05-15-2008, 05:38 AM   #8 (permalink)
The Anti-RUB
petrock's Avatar
As others have said, the engine oil plug is under the bike on the right side.
I replace if the o-ring/gasket are damaged or appear worn out in any way. 28k miles on my ride and have only changed the engine oil o-ring twice. Once for the primary o-ring and once for the tranny o-ring.
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 05-15-2008, 07:59 AM   #9 (permalink)
Works for him... I change 'em each time. For the little money, I just make sure they're "fresh".
ChopperDude
Old 05-15-2008, 01:30 PM   #10 (permalink)
Wisyooper is on a distinguished road
I change the fluids in all three holes frequently. I usually re-use the rubber o-rings on the engine oil plug and the transmission plug. If they look damaged, I replace them. I just keep a supply on hand - they are cheap.
Same goes with the gasket on the primary - I usually re-use but have a new one on-hand just in case.
Wisyooper is offline   Reply With Quote
Old 05-24-2008, 12:27 AM   #11 (permalink)
Stalin is on a distinguished road
anybody got an idea of the o-ring size? I decided to do my last fluid change and withhold paying dues to the motorco and the o-ring has been shredded. I used the search function but couldn't find the info...
Stalin is offline   Reply With Quote
Old 05-24-2008, 03:58 AM   #12 (permalink)
eagle56 is on a distinguished road
anyone use an oil suction pump
eagle56 is offline   Reply With Quote
