I posted this in tires and suspension..hope it isn't against the rules to post it here too...
Another exercise in deductive reasoning...
I have an 07 Fatboy...it seems to be uniquely blessed with extremely offset front end that neither the 08 or 06's and prior had.
I would like to run a Custom Softail (or compatible) front end. Obviously the front wheel ( and therefor the rear?) offset is different on a Custom Softail and a Fatboy. I have a Softail rear chrome swingarm (PN 48607-06)which is stated as compatible with both my 07 Fatboy and all 07 + 06 Softails with a 200mm wheel.
I think if I want to run the Custom Softail front end, I need to buy a Custom Softail rear wheel and use Custom Softail rear wheel spacers...then the rear end will be spaced like a Custom Softail since we both use the same swingarm. If I were to buy the HD inverted front end for the Custom Softail and again use a Custom Softail compatible wheel and Custom Softail spacers, the front end should align with the rear..just as it would on a Custom Softail which uses the same frame...does this make sense??
Things which give me pause in my deductions and things I would really like to know..
I have heard the offset in 07 is due to the engine being moved in the frame..not sure what that is to facilitate BUT, why are the other 07 and 06 96", 6spd, 200mm Softails not offset like this? Why were the 06 SE Fatboys with 6 spds and 200mm rear wheels not offset like this?
Are all 07 96", 6spd, 200mm softails using the same frame?
Is it the same as all the 06 96", 6spd, 200mm Softail frames?
Do all the above have the engine mounted in the same place?
Are all the 200mm 06 and 07 Softails swingarms the same?
..or simply, how can I change my 07 Fatboy front end to a regular fork setup and maintain my alignment\balance so I don't die in a 30mph speed wobble?
