Largest Tire on FXST 21 x 2.15 Front Rim? : V-Twin Forum: Harley Davidson Forums
Old 02-07-2008, 10:28 AM   #1 (permalink)
DLRVelocity1's Avatar
DLRVelocity1 wants to know Dino or Syn?
What is the largest tire that will fit on a stock FXST front rim? Have a buddy who is getting ready to replace his original and would like to put the tallest and widest tire he can on the front. He wants to close up some of the gap between the stock fender and the tire for a more custom look while putting more rubber on the road too.
Thanks,
V1
'02 FX"C"ST
98 Screamin' ci.
Hillside Stage 3 Heads
TP Rollers and Box Assy's
HQ Cams Wood Helical gears
Crane Easy Adjust Rods / S&S Travel Limited Lifters
Bob Wood Performance 415 Carb
Ness SS w/Zippers filter
SE 2/1 Pro Pipe "V&H" Custom Billet End Cap
Daytona Twin Tec Ignition
Baker 3.48:1 Gearing
SE / Barnett CF Clutch
Weld Recluse Wheels, Rotors and Pulley
Ness / Cycle Visions Custom 5" Fwd Controls
V1 Engineered 200mm Tire Retrofit
DLRVelocity1 is offline   Reply With Quote Quick reply to this message
Old 02-08-2008, 08:37 AM   #2 (permalink)
The Anti-RUB
petrock's Avatar
With a stock rim and stock fender, I would go with a 90/90-21 from Metzler. The 80/90-21 is the stock size. Any bigger then 90/90 and you get into clearance issues with the fender. Good luck...
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
