Originally Posted by Boomshaw
Okay,
Anyone got a Softail and is running the Daytona TwinTec or the Zippers (Thunderheart) Thundermax system? How did you install your O2 sensors so that they looked the best and were discrete? Pix? Thanks!
ZIPPERS TMAT bought D&D fatcat for 2007 model and it fir just fine on my 2001 FATBOY just got an oil cooler and it is tight but not touching.....GOOD LUCK
WMOSSY
2001 FATBOY 117" Axtell cyls, Axtell Pistons, R&R Stage V heads, RR615 cams, R&R Rollers, R&R internal Cam plate & New HO OEM pump, ADJ pushrods, SE CVO 4 3/8 crank worked by DARKHORSE, Zippers 54mm TB & 1.8 Manifold, 2001 VROD injectors, K&N open Filter, D&D 2:1 with perf baffle, Rivera Pro Clutch, basket & TPP, TMAT Map 514, HD PREM Oil cooler, BAKER DD6
