Originally Posted by bcitori
I have 10.25 to 1 big bore pistons with Andrews 37b cams. I have a Power comander III and had it tuned at three different
places about 5 times in total, and nobody can get rid of the pining. They say they have taken timing out to the point that no more can be pulled out with the PCIII. I am told the cam and piston combo is not a good match. What are my options the pinging is driving me crazy.....
first off i assume your running high test gas correct? seems like a no brainer but ive seen worse.
second how do you ride? with high compression pistons and cams you cannot ride it like a stock bike and lug it. you have to keep the rpm's up especially when you have a passenger or are going up a hill. you cannot do a hard roll-on from low rpm cruise speed.
third if your riding it in hot weather and you dont have an oil cooler, get one. heat is the cause of pinging. its the fuel actually detonating when it isnt supposed to caused by superheating it to the point of it exploding.
and i agree that there is no point in adding a thicker head gasket to lower compression. it is counterproductive of adding high compression pistons in the first place.
i live in texas and have built many bikes with big bore and 10.5:1 compression pistons without any problems with pinging. it all comes down to the way you ride and the way it is tuned. period.
