Let's see everyone's FXR - Page 135 : V-Twin Forum: Harley Davidson Forums
Old 12-17-2012, 10:04 PM   #2011 (permalink)
The Best Me I Can Be
Homesick's Avatar
Homesick is on a distinguished road
Originally Posted by Michael Psycle View Post
Because white is the absence of black.
White
Originally Posted by cwilks View Post
Doof
bikes
Originally Posted by ALAY191 View Post
I do ... though I prefer PoPo Birch White. Had a white '83 FLHP back in mid '80s then had it re-done in police Black/White for a spell.
rock.
Keep The Change
Homesick is offline   Reply With Quote
Old 12-17-2012, 10:06 PM   #2012 (permalink)
Homesick's Avatar
Originally Posted by Thermodyne View Post
The color is not so important. So long as it shines well, with the decals and pinstripes nice and blended smooth, or even deleted. It'll look good.
But then as I think about it. If you rode more and looked less, the paint wouldn't really mater at all.
Logic and reason have no place in this conversation.
Keep The Change
Old 12-17-2012, 10:08 PM   #2013 (permalink)
Homesick's Avatar
Like this one?
You missed my birthday last summer, but Christmas is here; and I'm still eyeing those pedals.
Keep The Change
Old 12-18-2012, 06:25 AM   #2014 (permalink)
Laughing Poseur
cwilks's Avatar
cwilks is on a distinguished road
thanks man.
is the passenger seat cut down? it looks a bit lower or it might be just the angle.
it's just the angle
cwilks is offline   Reply With Quote
Old 12-19-2012, 08:23 PM   #2015 (permalink)
Ltank is on a distinguished road
2000 fxr4 cvo
Hi Guys,
Are they ever finnished? Well anyway the bike a S&S V111 motor 4.125" Bore/Stroke 116HP 5600 RPM/ 122 TQ 3800. Custom Stainless Steel Stepped two into one collector.
Rivera-Primo 6 Speed O.D. transmission, 30 tooth tranny and 58 tooth rear wheel pully and a Barnett Scorpian Clutch.
Fat Bob FXDF chromed lower legs, Wide Glide FXDWG fork tubes, Progressive heavy duty fork springs, Ricor Intiminators, Custom Cycle Eng. 49mm Tripple Trees, 3/4" axle for stock wheel, stock brake calipers. The CCE rotor spacers were modified as were the axle spacers. Flash Motor Works made the custom billet fender brackets to allow use of stock front fender. YSS 14" RZ 366-360 shocks with progressive springs and adjustable rebound.
I hope I posted the photo correct. If not how do I attach a photo?
Ltank
Ltank is offline   Reply With Quote
Old 12-20-2012, 10:35 AM   #2016 (permalink)
Thermodyne's Avatar
Thermodyne is on a distinguished road
Originally Posted by Ltank View Post
Hi Guys,
Ltank
I don't suppose you'd be wanting to trade your side covers for a pair that already have some custom art work?
"All mankind is divided into three classes: those that are immovable, those that are movable, and those that move."
Thermodyne is offline   Reply With Quote
Old 12-20-2012, 07:21 PM   #2017 (permalink)
Homesick's Avatar
I got dibs on all side covers.
Keep The Change
Old 12-20-2012, 07:36 PM   #2018 (permalink)
Thermodyne's Avatar
Works for me. Do you have a set of plain yellow cvo covers to trade?
Old 12-29-2012, 07:42 PM   #2019 (permalink)
1991 fxrs's Avatar
1991 fxrs is on a distinguished road
Lets see everyones fxr
My 1991 fxrs. Had it since 2001.
1991 fxrs is offline   Reply With Quote
Old 12-30-2012, 09:25 AM   #2020 (permalink)
Homesick's Avatar
(I somehow missed this post.)
No sir, I don't. But I'd be happy to owe them to you.
Keep The Change
Old 01-01-2013, 08:16 AM   #2021 (permalink)
ALAY191's Avatar
ALAY191 is on a distinguished road
Happy New Year y'all
AL
ALAY191 is offline   Reply With Quote
Old 01-01-2013, 09:17 AM   #2022 (permalink)
BigPeet is on a distinguished road
Hey Al, I dug out a set of stock grips and fat pegs for you. I'll be going to Webster this Sunday and will pick you up a pair of mirrors.
~Pete
BigPeet is online now   Reply With Quote
Old 01-01-2013, 11:09 AM   #2023 (permalink)
ALAY191's Avatar
~Pete
Thanks Pete.
I found the source of the oil leaks.
One was the oil pressure feed and the other was oil pressure built up and blew the oil cap half way out of the tank. The only thing that stopped it was the bottom of the seat.
I got the RaceTech springs and emulators in the forks now with modified damper rod and 20W oil. Handles amazing even with the Progressive shocks. Next time I'll add the taller WorksPerformance shocks.
I also scored FXLR gas tank for $30 !!! another $30 bought me a FXRT couch of a seat and a FREE Conv windshield. Its pretty beat up from storage with very few tiny cracks and a nice frame with all the clamps.
AL
Old 01-01-2013, 12:46 PM   #2024 (permalink)
TX87FXLR is on a distinguished road
My 1987 FXLR
It's a work in progress. I work on it as much as I can. Since the pictures were taken I have put a S&S super E on it and working toward Andrews EV27 cam.
The Thunderheader has had 5 1/2" taken out. I'm going back and forth between high temp powder coating or header wrap.
TX87FXLR is offline   Reply With Quote
Old 01-01-2013, 06:38 PM   #2025 (permalink)
kennyflhr's Avatar
kennyflhr is on a distinguished road
This is my 93 FXRS. so far I've put a 39mm sportster tree with tubes from a 96 Dyna lowrider with Race Tech springs,dual disc brakes,8 1/2" t-bars with 96 & up controls, mini signal/running lights, LePara bare bones solo seat(& 2 others also), 11" progressive shocks w/ heavy duty springs. The motor is S&S cases w/ S&S 4/58 crank 3 1/2 bore S&S pistons(89" stroker), Custom grind cam, S&S lifters, v-thunder push rods, 5 angle valve job with mild pocket port, black diamond valves,S&S roller rockers, S&S"E"carb,thunderheader, & ultima single fire ign with taylor wires.
ID:	75582   Click image for larger version
ID:	75583   Click image for larger version
ID:	75584   Click image for larger version
ID:	75585   Click image for larger version
Ride it 'till the wheels fall off!
kennyflhr is offline   Reply With Quote
