upgrading front end opinions..race tech? 41mm? : V-Twin Forum: Harley Davidson Forums
Old 02-14-2017, 12:43 PM   #1 (permalink)
800screws wants to know Dino or Syn?
looking to tighten up the front end on my 88 fxr.....it has a single caliper....whats gives the best results for aggressive riding? just upgrading the 39mm forks with race tech valves and springs and a fork brace?
or
going to a 41mm front end kit...I would go with a dual caliper front system if I went this route...
looking for some opinions...
800screws is offline   Reply With Quote Quick reply to this message
Old 02-14-2017, 01:17 PM   #2 (permalink)
Master Motorhead
Thermodyne's Avatar
Thermodyne is still riding a stock bike Thermodyne is still riding a stock bike Thermodyne is still riding a stock bike
Just rebuild what you have with emulators and new springs.
If you want it to stop better, then you'll need a right lower with caliper bosses. And the parts to put brakes on the right.
Thermodyne is offline   Reply With Quote Quick reply to this message
Old 02-14-2017, 05:52 PM   #3 (permalink)
cbellamore wants to know Dino or Syn?
or
I just went through this with an FXR I re did, if you really know how to ride and you ride aggressive
dont even bother with the 39mm, even with the cartridge type fxdx 39mm with tricked up internals etc and adjustable everything, the forks still are weak,
look at some of the inverted front ends out there on the market, fab kevin makes a nice one and so does gigastatt,
by the time you drop all the money on setting up a 39mm your not too far off from what a set of drop trees from those guys and a pair of sport bike tubes would cost, plus you get the bolt on radial mount brakes with bigger rotors etc.
Thats the direction Im going when I do my next FXR over which I just started on this week
cbellamore is offline   Reply With Quote Quick reply to this message
Old 02-14-2017, 06:05 PM   #4 (permalink)
compressor#v wants to know Dino or Syn?
I upgraded with my 39mm (dual disc) with Racetech springs and gold valve emulators for $321.00. With sticky tires, aggressive riding in the switchbacks very good IME. A 41 mm front end from a late Dyna is still gonna need a upgrade. A inverted front end with the correct trail and ride height and brakes will cost 3 grand. Well worth it if you have $$$.
compressor#v is offline   Reply With Quote Quick reply to this message
Old 02-14-2017, 07:15 PM   #5 (permalink)
ecir45's Avatar
ecir45 is reading this now saying WTF is this?
Are you saying you ran gold valve emulators in regular front end and a fxdx tricked out front end and wasn't satisfied?
ecir45 is offline   Reply With Quote Quick reply to this message
Old 02-14-2017, 10:03 PM   #6 (permalink)
they certainly are an improvement over stock setups theres no debating that
but the 39mm front ends still kinda suck
figure new for tubes and a racetech kit with speed merchant pre load adjusters and your around $700-$800ish
at that point sell your 39mm front end and invest in something better if you really want to improve the front end as best you can
now if you just ride the bike normally than keep the 39mm
again just my opinion
the next fxr im starting on now i will be keeping for myself and im definitely not putting a 39mm front end on it
Old 02-15-2017, 11:26 AM   #7 (permalink)
Master Motorhead
Thermodyne's Avatar
Other than the look, I fail to see why people are willing to drop thousands of dollars for inverted forks and different calipers that go with them. Then put it on an FXR.
It a rubber mounted drive train, with frame angles more in tune with cruising than running corners. It also has a poor lean angle unless you jack it up, which makes the cg less manageable with each additional inch. You'll never lean an FXR enough to make use of that inverted front end. And the brakes are just overkill for the weak of hand.
But it does look cool. And some posers feel the need to ride scooters that look fast.
Old 02-15-2017, 01:03 PM   #8 (permalink)
I would agree with that also,
but like I said if your really looking to ride the bike as hard as possible the 39mm front end is still a little flimsy and not all that ideal,
I agree the FXR will never be a replacement for a sport bike,
I have owned Ducati Superbikes and also Honda RC51's
you will never get an FXR to handle like one of those
the factory 39mm front end with the internal upgrades and a set of HD touring brembos will get the job done for 90% of the people out there, most people can not ride their own bikes to their full potential,
but there are certainly better options out there in the front end dept. for the other 10% that are capable riders
Old 02-15-2017, 01:05 PM   #9 (permalink)
Master Motorhead
Thermodyne's Avatar
Those guys, the 10%, they laugh at Harley's with inverted forks.
Old 02-15-2017, 01:14 PM   #10 (permalink)
051
051 wants to know Dino or Syn?
Just trying to clarify this, I couldn't tell from your response if you personally did or did not?
51
051 is offline   Reply With Quote Quick reply to this message
Old 02-15-2017, 01:18 PM   #11 (permalink)
Van_Kerr wants to know Dino or Syn?
I've got a 1992 FXR, changed the front forks (43mm) for a combination of Kawasaki Zx9 (bottoms) and Yamaha XJR 1300 (tubes). I've now have tubeless tyres with fitting the Kawasaki wheels and a REAL benefit of having six pot calipers each side up front .................. went this route after fitting an S &S 113" motor, worth EVERY penny (cent), of which there were lots. Not for purists !
Van_Kerr is offline   Reply With Quote Quick reply to this message
Old 02-15-2017, 04:24 PM   #12 (permalink)
51
I did run them
I wouldnt say that i wasnt satisfied
like i mentioned they are an improvement over stock
but still leave a lot to be desired and if you price the stuff out your not far off from buying a much better front end and brake setup
figure a 39mm fxdx front end used sells for around $900-$1200 depending on what you find out there
racetech internals add another $400 ish
radial brake caliper adapters i think are $250
and you will spend another $150 for a good pair of radial mount brakes
another $200 for floating rotors minimum
brake hoses, hardware etc and your just about at $2k
so my point is if your are going to start from scratch dont bother with the 39mm
at $2k you can buy some drop trees and a sport bike front end and put a nice front end together yourself if you know how to measure for an axle and wheel spacers and shims etc
even less if you can make those pieces
if you have an fxdx front end
dont buy the parts to upgrade it
sell it and use the money you get to buy a better front end
thats what i meant in the above response
again to each his own
im not a fan of the 39mm front end when compared to what else is out there
Old 02-15-2017, 06:17 PM   #13 (permalink)
FXDRYDR is still riding a stock bike FXDRYDR is still riding a stock bike
Have to agree.
I did all of the above to my 39mm forks + added the second disk, a fork brace and Works on the rear. It's a night and day difference from stock. But the FXD is still a 650#-ish lump with a rubber mounted motor and rear end. Kinda like putting stiffer shocks on a 70s-era Cadillac boat and expecting a Corvette. That the FXD ain't no sportbike is driven home to me every time I hop on my pretty much bone-stock Buell tuber. That mofo is on rails at 90 MPH and turns by thought and with zero drama or instability.
Again, it's a substantial upgrade from the pig-like handling of the stocker and worth the cost. But doing more is a waste IMO. Gotta manage the expectation.
FXDRYDR
2003 FXD
124
Black, chrome & loud.
Old 02-15-2017, 06:57 PM   #14 (permalink)
pwmorris is reading this now saying WTF is this?
Buell XB-
A ton lighter.
pwmorris is offline   Reply With Quote Quick reply to this message
Old 02-15-2017, 07:18 PM   #15 (permalink)
ecir45's Avatar
That's what I was thinking inverted fork equals lighter bike = well .
