RevTech Six Speed : V-Twin Forum: Harley Davidson Forums
Old 12-05-2012, 01:43 PM   #1 (permalink)
FXRS84 is on a distinguished road
RevTech Six Speed
Someone has offered me a deal on a RevTech 6spd that is
for my FXR, up to E84... Has anyone a comment they would like to make on the RevTech..trans.. It is no longer current in the RevTech catalog, and the offer is about 33% off, but I dont really need it now.
FXRS84 is offline   Reply With Quote
Old 12-05-2012, 01:58 PM   #2 (permalink)
lucille is on a distinguished road
Although this isn't exactly the same .....
Have an 'early' Rev-Tech six speed gearset in the OEM five speed transmission case.
This was installed by the previous owner. I've had absolutely no problems with it. I seldom use the sixth cog ...... just don't have the roads here for it.
Greg
lucille is offline   Reply With Quote
Old 12-05-2012, 04:00 PM   #3 (permalink)
Thanks Greg, actually I think that I may have assumed that it would be realized that
I am asking about a 6 spd gearset to go into a OEM trans case.
So I think we are talking about the same. With a good report on the 6 spd,
then I need to decide if I should get it, even though I dont really need it now.
Old 12-05-2012, 06:56 PM   #4 (permalink)
BUBBIE is on a distinguished road
I installed that gear set (rev-tech 6 speed) Wayyyyy back in ?? 03 in my 00 FXDS TC. Built motor also 95" with lots of goodies. Never dyno'd but built after one that dyno'd 100 HP and 110 torque.
I bought the gear set at JP Cycle catalog, seems they were really proud back then 1450$ I seem to remember. May have included some other parts with that gear set?
I Installed it keeping in mind to have the shifting adjustment so it would shift UP into gear (more movement) using a little more on the adjustment then shifting Down (it would always pull into gear no issues. It did Like the little more UP a gear then down... First setting and together PERFECT...
That really was a good set up for my bike.
I Used ONLY Redline ShockProof Heavy in it and I put well over 60,000 miles on that gear set.
Back then, Baker would not warranty any of the installs that went into Harleys ,,, even when the HD dealer installs one,,,, UNLESS ShockProof Heave was put in it...
Back then there was saying about the rev-tech stuff, not holding up and calling them JUNK,, BUT I never had one problem with it..NONE...
I am a FIRM believer in Redline products and Used them all in my bikes for many fault free miles. MTL in the primary also gave me 117,000 miles on that bike USING the stock clutch... All still ran and worked good when sold and bought my 09 FLHR. Still using Redline products there. SMILE...
Hope you get that gear set and maybe mind telling me how much$$ it costing you. I have seen them as low as 950$ once...
signed....BUBBIE
Added:
I forgot to add,,,,The speedo shows @ 25 miles per hour when you're going 50....Exactly 1/2 of the speed... You can buy a converter BUT it is easy to get used to the 1/2 speed and remember that also is 1/2 the mileage that shows also.
BUBBIE is offline   Reply With Quote
Old 12-05-2012, 07:16 PM   #5 (permalink)
BUBBIE ...... I use Redline in mine also.
Old 12-05-2012, 09:50 PM   #6 (permalink)
springer-'s Avatar
They don't call it wreck-tech for nothing. I am not sure about your specific tranny you are asking about but they had a bunch of problems with the 6 speeds iirc.
As a general rule I stay away from wreck-tech. JMO.
Old 12-05-2012, 10:01 PM   #7 (permalink)
Laughing Poseur
cwilks's Avatar
cwilks is on a distinguished road
I had a RT 6 speed gear set I ran for 5 years behind a 140 hp motor with a 240 tire.....in fact....it's still in the bike...no problems at all. I know guys who have problems with Bakers too...YMMV.
cwilks is offline   Reply With Quote
