forward controls? : V-Twin Forum: Harley Davidson Forums
Old 11-25-2012, 06:22 PM   #1 (permalink)
wrencher is on a distinguished road
forward controls?
I have forwards on my 84 fxr and i dont like the brake control pedal.its to high and there is no adjustment.any books I look at show pretty much the same thing.the guy at the local shop says that is a problem with fxr's.is there something else out there i can use?
Own the power,
sieze the hour,
ride the dream.
wrencher is online now   Reply With Quote
Old 11-25-2012, 06:34 PM   #2 (permalink)
Greg MacD's Avatar
Greg MacD is on a distinguished road
The Front brake?
2006 FLHTPI
2003 Aprilia RST 1000
2004 Suzuki DRZ 400 (Motarded)
2003 Ford SD 7.3L Diesel
Greg MacD is offline   Reply With Quote
Old 11-25-2012, 07:12 PM   #3 (permalink)
Originally Posted by Greg MacD View Post
The Front brake?
I asked for that one
Own the power,
sieze the hour,
ride the dream.
Old 11-26-2012, 07:26 PM   #4 (permalink)
ole57's Avatar
ole57 is on a distinguished road
I think I've read that guys use an flh pedal to help with that problem .I think the way that it bends back towards the rear works better .
are you kiddin me ?
ole57 is offline   Reply With Quote
Old 11-26-2012, 08:38 PM   #5 (permalink)
OK cool thanks for the info
Own the power,
sieze the hour,
ride the dream.
Old 11-27-2012, 06:35 AM   #6 (permalink)
chilsam's Avatar
chilsam is on a distinguished road
Aftermarkets
Love the ones I have.
chilsam is offline   Reply With Quote
Old 11-27-2012, 07:26 AM   #7 (permalink)
FXRS84 is on a distinguished road
your adjustment is how far you screw the brake rod in the plunger for the master cylinder. set it up without using the spring and boot. After you have it adjusted, then assemble with sping and boot. Some fowards have a threaded end on both ends
of the brake rod, that may give you a litltle more adjustment.
FXRS84 is offline   Reply With Quote
Old 11-27-2012, 08:05 PM   #8 (permalink)
OK will look at the linkage again and maybe show a pics of what i am talking about height wise.because as it is now you have to lift your foot up off the peg to operate the brake
Own the power,
sieze the hour,
ride the dream.
Old 11-27-2012, 10:44 PM   #9 (permalink)
Lakerat is on a distinguished road
Mine adjusted with the rod to where it is right at the tip of my toe after cutting off the arm and drilling a new hole for the peg. Picture of yours really would be helpful.
92 FXLR
97 Ultra (RIP)
98 95th Anniversary Ultra
PGR
Lakerat is offline   Reply With Quote
Old 11-29-2012, 03:25 PM   #10 (permalink)
I have mine adjusted so that There is no play in the brake linkage ,and no pressure on brake. Then assembled with spring and boot over plunger at master cylinder. Though I do have to raise my foot, felt it important to be able to reach (I'm not real tall) and get the brake working as best I could. I'm already braking w the front unit. And thats
75-80% of your brakeing. Play with it do what feels good for you. but you will find it much easier to figure out by not having the return spring installed for your initial adjusts
Old 11-30-2012, 09:13 AM   #11 (permalink)
thebreez's Avatar
thebreez is on a distinguished road
I don't think FXR's ever came with forwards, you got some after market something or other. Look at forward controls, you will see a difference.
1994 FXRP SE Heads, 42 Mikuni, EV46Cam,
Dyna SF Ignition, Bub 2into1, 10to1 Compression.
Lockhart oilcooler
Love the Torque
thebreez is offline   Reply With Quote
Old 12-02-2012, 08:54 AM   #12 (permalink)
brake control pics
here are some pics of the brake control even with threading the adjusters in I dont think it will bring it down enough.Local bike shop suggested cutting an rewelding where i want it.then rechroming
Name:	fxr forward brake 001.jpg
ID:	75088   Click image for larger version
Name:	fxr forward brake 002.jpg
ID:	75089   Click image for larger version
Name:	fxr forward brake 003.jpg
Own the power,
sieze the hour,
ride the dream.
Old 12-03-2012, 12:56 PM   #13 (permalink)
You are quite right They never came with fowards, in fact, to get the most handling out of your FXR, you would be better off with mids. or factory controls.
I dont recognize that set up. Dont know if that is a kit or was someone sharp enough to make their own out of some spare parts.
Like that boot heel guard. Is that a fabbed peice.
If you are going to cut and weld!! Make your measursements
Without the return spring in at the master cylinder.. it worked for me. Hope you get the results you want.
Old 12-03-2012, 07:43 PM   #14 (permalink)
the heel guard is a fabbed piece the previous owner found a guy who built them an was gonna start manufacturing them on a larger scale but passed away before he could do that.so might be the only set out there. they are comfy once you get used to them either have your heel up against them or resting on top of them.70 miles an hr an your feet dont slip off the pegs they also are the mounts for the driving lamps.I dont think I will cut the brake pedal up.might just look into a different set up.I know what you mean about mids my 81 sporty had mid controls but i kind of like this set up
Own the power,
sieze the hour,
ride the dream.
