11-21-2012, 02:37 PM
FXRT compatible shocks
I need new shocks for my FXRS-FXRT conversion and want to go with the air shock to go with the rest of the FXRT parts (fairing, bags). It looks like lots of used bagger air shocks are available on ebay for a good price but if you search for FXR the price jumps. Does anyone know which of these 13 in. air shocks fit on an FXR frame?
11-21-2012, 07:33 PM
The Best Me I Can Be
My bud said the air shocks on my 84 FXRT were the same as on his 89 FLH. I wouldn't be surprised if he wasn't thinking about length, but don't know. Don't know if this helps any, but it's all I got.
Keep The Change
11-22-2012, 01:04 PM
Touring air shocks 13" or 13.5" depending on preference set at 45psi will give a real nice ride on that scoot.
Joe
11-22-2012, 09:09 PM
Joe
Wow! Sounds a little stiff!
~Pete
11-22-2012, 09:19 PM
~Pete
The fender decal says 40 PSI max, for the '84 set-up (both shocks are air shocks). I run about 20 lbs.
Keep The Change
11-23-2012, 12:41 AM
I was doing my 2011 on the cheap before getting the parts I REALLY wanted...
The front suspension is ket stock, however I did swap out the fluid Maxima 15W oil went back in. The rear suspension is a 13" setup off of a 2012 Electra glide. It is air/oil and has the schrader valve hidden under the seat for adjustability..... after lots of experimenting in 2psi increments up to 58psi...I have it setup at 45psi and it rides and handles like a champ.
I weight 200lbs.
Joe
11-23-2012, 05:21 AM
I am a little confused why sometimes the FXRT had 2 air shocks and sometimes only the right one was air. One person suggested that the left air shock interfered with the belt drive. Others say no. Just curious
11-23-2012, 06:09 AM
Joe
I guess it just depends on what year shocks you use. My '98 RK says 35psi max. My buddies '03 RK says 35psi max, but he put HD Low-Profile shocks on...they say 50psi.
Late model, possible '09 and up say 50psi. Go figure.
~Pete
11-23-2012, 04:12 PM
I've wondered that too. Maybe 2 different types cover for each other's weaknesses; kinda like my roscoe has 2 springs, one inside the other.
I have no problems between my belt and the left side air shock.
Keep The Change
11-23-2012, 07:38 PM
I have a set of stock shocks for my 89. 1 Air shock one regular shock...
right air shock would be
150lb rider 0-5 psi
for each 25lbs add 5 psi
passenger weight for each 50lbs add 10 psi
luggage weight per 10lbs add 3 psi
MAX PSI 60.
right is the only air shock.
at any rate I would be willing to bet all FXRTs had that set up...I'm not positive though...but It's original for 89. oh they're 13 inch. I have 13 1/2 konis so it sits a tad higher when parked. but when i get on it, It levels out...I love the KONIS. Pretty sure I'm repeating myself with this post anyhow...the original factor is also cool...I don't know any other bike that has 1 air shock and 1 regular shock. hehe but they cost big dollars, not many RTs to being with. let alone stock shocks...big dollars =p
11-24-2012, 06:41 PM
I also have the same setup as Dave 89fxrt on my 86 fxrd. Bought it new so no modifications yet. Has anyone tried lowering this bike? Also would like to upgrade the brakes. I have been riding a Buell S3 for the last several years and it's handling and braking have me spoiled.
04-06-2013, 08:20 AM
there is only 1 air shock on some fxrt models due to the year and frame design. on the 1986 model it came w 1 air shock and 1 regular . the air shocks back then were much fatter. additionally the introduction of the final belt drive is another consideration. prior to changing the frame to accomadate the thickness of the belt, a regular hydraulic shock was used on the left (or belt side). Hope this helps add to the confusion
04-06-2013, 08:44 AM
so, do any of you who switched from conventional to air shocks prefer air?
AL
04-08-2013, 03:01 PM
My 85 frxt rides like a dream compared to my 03 flhtc. they called it split fork suspenshion. i have a stock set of these with 8k mi's , keeping them for a spare set , probably never use them but if someone needs a set in exc-cond. they can pm me for pic's and will sell for $200- shipped.
| Sponsored Links |
