Oil hose 90deg bend solution : V-Twin Forum: Harley Davidson Forums
Old 11-10-2012, 01:48 AM   #1 (permalink)
BIGBOPPA is on a distinguished road
I put a torque plate on my '86 FXR but had trouble with the return oil line, as I had changed it out recently, but couldn't find a hose with a 90deg bend as they aren't available anymore. I have seen this discussed on here a few times and most people have just used straight hoses or 90deg fittings, both of which work OK unless you wanna put a torque plate on! So to solve the situation I went to the local hose and fluid connector supplier and bought the pieces to make a right angle turn that would clear the transmission and the torque plate. Here is a link to some pics of the parts needed and how it goes together:
http://s225.photobucket.com/albums/d...20Line%20Pics/
BIGBOPPA
MICAH 6:6-8
PLEASE,DO NOT MAKE ME HAVE TO USE MY UNDERTAKERS VOICE!!!
1986 FXRS
80" EVO
Andrews EV27 Cam
V&H RSD Tracker 2:1 Exhaust
Mikuni HSR42 Carb.
Ultima Single Fire Ignition
Wide Glide Conversion
Fork Brace
Progressive Front Springs
Koni Rear Shocks
Spherical Bearing swingarm upgrade
Rear stabilizer
Torque Plate
Sports Front Fender
Custom Seat
Fatbob Headlight
Custom Air Dam
Custom Passenger Backrest
BIGBOPPA is offline   Reply With Quote
Old 11-10-2012, 09:19 AM   #2 (permalink)
Thermodyne's Avatar
Thermodyne is on a distinguished road
Brass fittings.....Blahhhhh.
Did you notice how small the passages were on those brass fittings? Notice the blunt corner on the elbow?
To flow properly you'd have to drill them out. Problem is that brass is too brittle and won't hold up to the vibrations after being drilled.
"All mankind is divided into three classes: those that are immovable, those that are movable, and those that move."
Thermodyne is offline   Reply With Quote
Old 11-10-2012, 03:56 PM   #3 (permalink)
I drilled them all out first and there is still plenty of meat on them, so, we'll see how it goes. It went fine on my long ride yesterday, so, so far so good I guess.
BIGBOPPA
MICAH 6:6-8
1986 FXRS
80" EVO
Andrews EV27 Cam
Mikuni HSR42 Carb.
Fork Brace
Koni Rear Shocks
Rear stabilizer
Torque Plate
Sports Front Fender
Custom Seat
Fatbob Headlight
Custom Air Dam
Old 11-10-2012, 04:32 PM   #4 (permalink)
Thermodyne's Avatar
Next time you need fittings, go to your local hydraulics supply house. A nice steel 90 degree swivel would have been perfect for that.
