are u using adjustable push rods? if it sounds like someone is constantly tapping on the engine-appears to be a lifter, also when u did top end, did u re-use oem pistons? or are u using high compression pistons? still sounds like a lifter? considering it is sensitive to temp. and amount of time running, lifter problems can fluctuate, problems in other areas are produce more consistent sounds
