help needed : V-Twin Forum: Harley Davidson Forums
Old 11-08-2012, 11:00 PM   #1 (permalink)
hdparadox is on a distinguished road
help needed
have a project and need some info .figured this was the best place to figure it all out.I ahve a 90 fxrs 60+thousand miles on it motor getting tired.Have in mind to tear it down remanufacture or spend $and get big motor.love the idea of big cubes but demand it be reliable.Any thoughts?
hdparadox is offline   Reply With Quote
Old 11-08-2012, 11:08 PM   #2 (permalink)
Conkljm's Avatar
Conkljm is on a distinguished road
You're likely to only do it once, so do what you really want. I'd go with Harley's remanufacture program.
Conkljm is offline   Reply With Quote
Old 11-09-2012, 01:26 AM   #3 (permalink)
Michael Psycle's Avatar
Michael Psycle will become famous soon enough
I wonder why the motor is getting tired after only 60,000 miles? My 92 fxr has over 100,000 and is still fine. Have you had the compression tested?
Michael Psycle
1992 Harley Davidson FXR
Michael Psycle is offline   Reply With Quote
Old 11-09-2012, 06:11 AM   #4 (permalink)
V-STRUM's Avatar
V-STRUM is on a distinguished road
I went the remanufactured route with my motor at 108,000 miles, not so much because it was tired but I wanted to go with the black and chrome finish, since I was redoing the whole bike after a little crash. The new motor is a little more oil tight, no base gasket leaks. It did burn oil like crazy though, found out 2 valve guide seals were installed wrong. Remember if you send in a modified motor you get a stock one back, so take it out the cams and things before you send it out.
If your just looking for more power, the standard mods, as well as having heads ported and polished might be all you need.
1987 FXRS-SP
2009 Aprilia Mana
2009 Suzuki V Strom 650
V-STRUM is offline   Reply With Quote
Old 11-09-2012, 10:51 AM   #5 (permalink)
Thermodyne's Avatar
Thermodyne is on a distinguished road
The MoCo rebuild program really is a deal. From what I've found out, you'll get a new lower end with your jugs and heads rebuilt. And all the bright work gets replaced. All for about $3500.
"All mankind is divided into three classes: those that are immovable, those that are movable, and those that move."
Thermodyne is offline   Reply With Quote
Old 11-09-2012, 12:59 PM   #6 (permalink)
gretsch58's Avatar
gretsch58 is on a distinguished road
+1 what Michael said. Have a leak down test done on it. I've got almost 60k on my 93. I've only replaced the lifters and cam. It doesn't even leak any oil and the compression is good. It's a strong motor still. pulls like a freight train.
At least by having it tested, you'll know where you stand with the motor.
My Frisco style bobber build.
"Why behave in public when you're living on a play ground" DLR
gretsch58 is offline   Reply With Quote
Old 11-09-2012, 03:04 PM   #7 (permalink)
Krowbar is on a distinguished road
is $3500 really worth it? Why not go with just a rebuild kit through NRHS or something? I want a big motor swap too, but I have decided, when it's time, to just rebuild the stock 80" motor to the walls. The motor only has 25k on it though so no rush.
1972 Superglide FX: Rebuilt, Super E, Drag pipes (FOR SALE PM ME)
2005 Sportster 1200: Thunderheader, SE ICM, SE carb upgrades, pretty stuff
1985 FXRS-SP: (looks VERY different than the pic. More black now) Dyna 2000 ICM, Twin Tec II Single Fire, Mikuni 42mm, S&S intake, Progressive springs, need money for Thunderheader and mid-controls! Have lot's to trade and $ if you have one for my bike!
Krowbar is offline   Reply With Quote
