Spark Plug Recommendations? 93 FXR EVO : V-Twin Forum: Harley Davidson Forums
Old 10-18-2011, 09:47 PM   #1 (permalink)
gretsch58's Avatar
gretsch58 wants to know Dino or Syn?
I'm sure this will get moved, just wasn't sure where to put it.
Just looking for spark plug recommendations. Stock EVO motor 46k miles. Thought I would ask you guys first since we all ride FXR's.
Appologies to the powers that be if I started this thread in the wrong place. Seemed like a good place to start off.
My Frisco style bobber build.
"Why behave in public when you're living on a play ground" DLR
gretsch58 is offline   Reply With Quote Quick reply to this message
Old 10-18-2011, 11:11 PM   #2 (permalink)
kennyflhr's Avatar
kennyflhr wants to know Dino or Syn?
I run Champion RN-12-YC. Stock heat range.
Ride it 'till the wheels fall off!
kennyflhr is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 08:38 AM   #3 (permalink)
mikeforcec51 wants to know Dino or Syn?
If you are using stock H.D. heads then I would have to say - use autolite, screaming eagle and or u-grove plugs. If you are using screaming eagle heads then you will need to use 12 mm plugs like NGK R and or screaming eagle. The reason for 12MM plugs, screaming eagle threads are that size.
I don't like champion plugs as once they are fauled, then throw them away. I don't even use them in my small engines - mower, chain saw, etc.
Make sure you are also using a good set of 8.8 MM or higher plug wires along with a high output coil - 3.5 ohms / screaming eagle, autolite, u-grove ,etc.
IF YOU ARE PICKY ON WHAT ITEMS ARE THE BEST 4 YOUR RIDE, THEN YOU WILL JUST HAVE TO DO A LOT OF TRAIL AND EFFORTS UNTILL YOU FIND WHAT THE BEST IS FOR YOU.
mikeforcec51 is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 09:02 AM   #4 (permalink)
Registered User
FXRS Carrera wants to know Dino or Syn?
Has anyone tried that "spitfire" plug or the "U" plug for their bike? Pros? Cons? Interesting thread....
FXRS Carrera is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 09:04 AM   #5 (permalink)
Swamprat Rider
JayFL459's Avatar
JayFL459 wants to know Dino or Syn?
Originally Posted by mikeforcec51 View Post
I
This is what I did and the Autolite work well in my FXR4 ..
2005 Dyna Superglide/ 2012 Vic Cross Country Stage 2/ 2015 Indian Scout Stage 1
JayFL459 is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 10:06 AM   #6 (permalink)
Laughing Poseur
cwilks's Avatar
cwilks is reading this now saying WTF is this? cwilks is reading this now saying WTF is this?
whats in it right now?
"There were no fuks given during the posting of this response"
cwilks is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 11:45 AM   #7 (permalink)
gretsch58's Avatar
ha! I'll look when I get home. I can't remember for the life of me. They came with the bike over a year ago.
My motor has stock heads. all stock as far as I can tell and what I was told. I checked the plugs during the summer and they looked fine, but have been thinking about upgrading some components to do this winter.
Old 10-19-2011, 12:57 PM   #8 (permalink)
Laughing Poseur
cwilks's Avatar
keep running em.....no reason to fix what ain't broke
Old 10-19-2011, 03:12 PM   #9 (permalink)
smitty901's Avatar
smitty901 is reading this now saying WTF is this?
Just run your stock standard HD plugs
Infantry leads the way
smitty901 is offline   Reply With Quote Quick reply to this message
Old 10-22-2011, 11:59 PM   #10 (permalink)
Throttle_Jockey's Avatar
Throttle_Jockey wants to know Dino or Syn?
Autolite # 65. You can get them at any Wal-mart in the country
FXR
Truett Chassis,XLH
Throttle_Jockey is offline   Reply With Quote Quick reply to this message
