Is your rear tire centered? : V-Twin Forum: Harley Davidson Forums
Old 11-17-2010, 12:37 PM   #1 (permalink)
Conkljm's Avatar
Conkljm is on a distinguished road
My rear tire is off-center, to the left (towards the belt drive) as I ride. I was told, "That's a normal problem with FXRs and the way they were designed." I'm now wondering how true that is after looking at some of the pics everyone has posted on the forum.
I worry because I hit some pretty mean "trenches" near bridges and I'm pretty sure the tire is hitting inside the rear fender.
At first I thought it was because of the spacer between the top of the Progressive shock and strut, but if the spacer was any smaller my belt pulley would rub the shock. The tire is straight, I'm not sure what to check next.
I have the Clymer manual, but it does not show the sizes of the spacers used.
Conkljm is offline   Reply With Quote
Old 11-17-2010, 12:43 PM   #2 (permalink)
Unca Mike is on a distinguished road
Ck
Sad but true. On my FXR4 anyway. Blows your mind doesn't it? Harleys.....!
Unca Mike is offline   Reply With Quote
Old 11-17-2010, 12:56 PM   #3 (permalink)
springer-'s Avatar
All stock FXR's are like that by design. My 1983 FXRT is also like that but runs very straight and true down the road. It has never effected handling on my bike.
Check out Ride of the Month
207-621-8089
Old 11-17-2010, 12:57 PM   #4 (permalink)
CuMoFo's Avatar
CuMoFo is on a distinguished road
Off Center
Yeah, your rim is off center. Get some calipers and figure out the sizes of spacer you need to center the rim, on some extreme cases you need to buy a pully spacer to re-align the belt.
CuMoFo is offline   Reply With Quote
Old 11-17-2010, 02:57 PM   #5 (permalink)
Conkljm's Avatar
Would the spacer go between the pulley and rim? I'm pretty sure they are bolted together right now, I'd have to look again to be sure. That would look really weird and I'd need longer bolts. However, if this is what you mean, then I could move the spacer from the right side of the rim to go between the pulley and rim.
Thanks for the replies thus far!
Old 11-17-2010, 03:03 PM   #6 (permalink)
springer-'s Avatar
There is no need to change the wheel spacing or use pulley spacers unless you are running a larger than stock tire. If it rubs the inner fender or bolts then that is what likely needs to be addressed. If it is a wider than stock tire, a FXR wide tire kit works well. JMO.
207-621-8089
Old 11-18-2010, 07:04 AM   #7 (permalink)
V-STRUM's Avatar
V-STRUM is on a distinguished road
My '87 FXR's rear tire was centered, but after a major rebuild in '03 (new frame with original swingarm) my rear tire appeared off center, also sitting more to the left. I've used 2 different rear rims with no change, thinking that this was the problem. I thought the swingarm was bent, bit it's straight, the shocks line up with the top and bottom mounts on the frame and swingarm. The bike handles fine, the rear wheel doesn't contact the fender within the rear shock stroke. Many mechanics are puzzled when they look at it, no one can figure it out. Since it functions fine I just go with it. My only suggestion to the OP is to take the shocks off and lift the rear wheel all the way up to be sure there is no wheel/fender contact.
1987 FXRS-SP
2009 Aprilia Mana
2009 Suzuki V Strom 650
V-STRUM is offline   Reply With Quote
Old 11-18-2010, 05:59 PM   #8 (permalink)
Conkljm's Avatar
I definitely have contact. I'm going to check on my tire size, although I'm pretty sure it's just a little wider than normal. Off the top of my head, I'm thinking it was an Avon at 140 wide.
Old 11-18-2010, 07:38 PM   #9 (permalink)
springer-'s Avatar
The stock tire would have been a 130 (pizza cutter) tire.
207-621-8089
Old 11-19-2010, 06:21 AM   #10 (permalink)
Quaddog is on a distinguished road
my '82 fxr looks centered. I was running an avon 140 without any problems and after it wore down I put on a 130 dunlop but only because I got a deal on it.
Quaddog is offline   Reply With Quote
Old 11-19-2010, 07:23 AM   #11 (permalink)
plugeye's Avatar
plugeye is on a distinguished road
years ago i worked at an indy shop.
we centered the wheel on my fxr to run a 140 tire.
something like a .200" spacer added to the sprocket side & milled the brake bracket the same.
plugeye is offline   Reply With Quote
Old 11-19-2010, 07:50 AM   #12 (permalink)
springer-'s Avatar
Here is a picture of my rear tire on a bone stock FXRT 1983. Compare the screw in the center of the fender with the tread.
This is the fat tire kit that centers the tire. No need to mill the wheel.
source http://vulcanworks.net/FXR-Fat-Tire-...set-p-416.html
207-621-8089
Old 11-19-2010, 08:32 AM   #13 (permalink)
V-STRUM's Avatar
"Here is a picture of my rear tire on a bone stock FXRT 1983. Compare the screw in the center of the fender with the tread."
Yup, that looks like mine. I feel a little better knowing that this seems to be a somewhat common problem.
1987 FXRS-SP
2009 Aprilia Mana
Old 11-19-2010, 10:39 AM   #14 (permalink)
springer-'s Avatar
It is not a problem. It is the way it is suppose to be. The tire didn't shift, the shaft isn't bent, the swingarm isn't tweeked, the shocks aren't bad. It is perfectly fine and exactly as it was intended. It is only perceived as a problem because we are trained to think it should be in the center.
Now by it not being in the center there is more clearence on one side of the tire than the other. If a wider than stock tire is installed, the side with less clearence can rub. The fat tire kit move the wheel and tire to the right .300" and puts it in the center of the fender and allows for a slightly wider than stock tire. I believe it will acommidate upto a 150 with the stock fender.
207-621-8089
Old 11-20-2010, 12:08 AM   #15 (permalink)
Conkljm's Avatar
Originally Posted by springer- View Post
It is not a problem. It is the way it is suppose to be...
Good posts everyone, thanks! I looked tonight and I was close. The tire is an Avon Venom-X, 150/70B18. Close to what I thought, but a little wider. My tire is off-center about as much as Springer's (thanks for the pics!) so I guess it's just the width causing the issue (TWSS).
Definitely going to check out the wide tire kit by Vulcan, it's much better than what I've found so far (replacing the whole swingarm, ouch!).
