Sealed Wheel Bearing Retro-Kits : V-Twin Forum: Harley Davidson Forums
Old 01-10-2010, 08:07 AM   #1 (permalink)
Bugger77 wants to know Dino or Syn?
Does anyone know if the Sealed Bearing Kits to replace the tapered bearings in early wheels can be still purchased and from who? They were originally made by FTM.
Bugger77 is offline   Reply With Quote Quick reply to this message
Old 01-10-2010, 11:46 AM   #2 (permalink)
Lakerat's Avatar
Lakerat wants to know Dino or Syn?
Hope someone chimes in here. I have looked for this conversion myself with no results. It may be that there is no source for a kit, but maybe someone has a parts list with the correct way to measure for the necessary spacers.
92 FXLR
97 Ultra (RIP)
98 95th Anniversary Ultra
PGR
Lakerat is offline   Reply With Quote Quick reply to this message
Old 01-12-2010, 12:34 PM   #3 (permalink)
baroth1 wants to know Dino or Syn?
well
A few years ago I talked to someone from FTM (Mario, I think) and was told that there wasn't enough interest to make another run of bearings. He had some kits left and would sell them, but did not anticipate any new ones being manufactured. I called because I wanted a few spare bearings for myself, all he would sell was the kits. I don't know if he still has anything left, but I would contact FTM and ask them.
http://www.ftmusa.net/
BAR
baroth1 is offline   Reply With Quote Quick reply to this message
Old 01-12-2010, 01:10 PM   #4 (permalink)
JohnC wants to know Dino or Syn?
Check out V-Twin part number 44-2995. I just replaced the front and rear timken bearings on my '99 softail (laced wheels) with these kits. The only thing I had to do was go with some custom axle spacers. I don't know why the description indicates "rear" since on my bike the bearings, sleeves, etc. are the same front and rear. So I took a chance and ordered two kits and they installed in my wheels with no issues.
Here's the description from the VT catalog:
Rear Double Row Retro fit wheel bearing kits for models with Timken bearings. Double-row wheel bearings eliminate wheel play, have a longer wear life, require no adjustment. Kits include two bearings, center spacer & spacers. Fit 1984-99 FXST, FLST, 1991-99 FXD, XL. VT No. 44-2995
JohnC is offline   Reply With Quote Quick reply to this message
Old 01-12-2010, 02:03 PM   #5 (permalink)
plugeye's Avatar
plugeye wants to know Dino or Syn?
what are you trying to accomplish?
fitting a bigger axle? going from superior weight bearing rollers to ball bearings buys you less maintenance i suppose...
for me, it made more sense to retain the rollers. inspect/ clean/ repack each tire change for peace of mind at least.
plugeye is offline   Reply With Quote Quick reply to this message
Old 10-29-2016, 05:00 PM   #6 (permalink)
Benyo wants to know Dino or Syn?
First post guys so take it easy, I ordered this kit for my 93 FXR im building, brought them to my mechanic and he did the rears but said on the fronts the spacer needed to trimmed down have any of you guys done this ? If so is it supper crucial how tight the tolerances are on the sealed bearings ?
Benyo is offline   Reply With Quote Quick reply to this message
Old 10-29-2016, 06:28 PM   #7 (permalink)
tall terry is reading this now saying WTF is this? tall terry is reading this now saying WTF is this?
Try VTWIN & DRAG SPECIALTIES. I used to get the out of the mainstream parts from them, among a few other suppliers...
You will need to measure and fabricate the wheel spacers... Sometimes a stock width spacer can be bought..
I did a lot of these conversions...having the bearing puller and driver tools simplifies this process... conventional tools usually won't work...you can save a bunch of money at an indy shop, take the wheels and kits in and let them change them, for a few bucks extra, they may set up the end play for you, it will be worth the cost...
tall terry is offline   Reply With Quote Quick reply to this message
Old 10-29-2016, 09:17 PM   #8 (permalink)
quadcam wants to know Dino or Syn?
Here ye!
Less rolling resistance too. I can understand going from sealed to rollers, but not the other way.
quadcam is online now   Reply With Quote Quick reply to this message
Old 10-29-2016, 09:26 PM   #9 (permalink)
Misters's Avatar
Misters wants to know Dino or Syn?
bad question...
Misters is offline   Reply With Quote Quick reply to this message
Old 10-29-2016, 09:33 PM   #10 (permalink)
I would have just left the tapered one in there, but i pulled the wheels completely apart to powdercoat, and before i did my research i ordered the sealed ones, so im going to run them for a while, and see how they do !
