If you take it apart again and push and release the front brake switch(the little black button) and you don't see the brake light operate, than you probably broke one of the wires on the switch inside the handlebar brake mount. I have an 86 fxst and the wiring is so old that everytime I do work like that, a wire would break off the switch and I'd have to re-solder it back on. I finally broke down and bought a new switch(with new wires pre-soldered on).
