When the engine is cold the fuel doesn't vaporize efficiently and more is required to run properly. This is what the enrichener is doing. As the engine warms to operating temp., the vaporization is better and the extra fuel is not needed. If you leave the choke full-on for the high idle as it warms...it will foul plugs. Best to pull choke for a cold start....then back it in as soon as possible, but leave it on a little to keep it running. As soon as you can shut it off and the engine still idles...do it. Set the throttle lock for a higher idle (with no choke) to finish the warm up.
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
