Originally Posted by dannyspade
Can’t get my brake light to turn off any help would be much appreciated…
I agree with your other replies, just to expand a bit... Had same problem as you. My "new for me" 84 FXR frt brake lever would SLOWLY return, brake light stayed on until the master plunger "lever" would depress the switch. (Recent colder riding here in WI magnified the problem.) If your lever isn't immediately coming all the way back when you release the brake, it's time to remove & clean or rebuild the master. The plunger bore in mine was contaminated with mung from years of old brake fluid & moisture, the plunger was sticking (typical on older bikes when the fluid wasn't serviced regularly). FYI I stretched the plunger spring 10mm for more release pressure on the plunger. Wet parts with fresh fluid then thoroughly bleed the system with HD recommended DOT 5 silicone brake fluid until nothing but fresh fluid comes out of the caliper. (A Mity-Vac brake bleeder makes bleeding the master and the rest of the system much faster. Tough to get the air out of the master without one, but not impossible.) If the plunger cap and/or piston o-ring is cracked or torn, etc buy a rebuild kit. HD discontinued the kit but you can buy an aftermarket online for around $16 plus shipping. From past experience, I've usually been able to clean & reuse the plunger and other parts if no damage is found, but you might want to get a kit beforehand just in case. Happy riding!
