Try bypassing the wiring by running a jumper wire to the coil straight from the battery. If the problem is in the harness or switches, it will run with the jumper. The other thing to try is to plug in a known good module. Every shop has one, and it should'nt be hard to find one to test with. If youre single fire, just disregard the second wire, and hook up a stock coil.
