CycleGear.comMotorcycle-CommunicationAmerican Side Road CycleDan Vance RacingProCharger.comFuel MotoMotorcycle.com Classifieds!JekillandHyde.euAdvanstarMotorcycleShows
Old 10-04-2009, 01:05 PM   #1 (permalink)
Ol' Biker's Avatar
Ol' Biker is on a distinguished road
Question Wide Glide Front What Fits An 84 FXRT?
Hi all, just a newbie here. I'd appreciate your expert FXR feedback! Looking to go with a better appearing front on my 84 fxrt (fairing & bags removed - bought it that way). I'm finding various OEM wide glide front end take off's online that fit my budget, just don't know what fits what, primarily the tree's & stem diameter? Must admit I love the ride & travel of the stock 35mm fork, so also considering a conversion. recommendations & suggestions? Thanks!
Ol' Biker is offline   Reply With Quote
Old 10-04-2009, 01:31 PM   #2 (permalink)
bkrhoades's Avatar
bkrhoades is on a distinguished road
I bought a 53mm inverted wideglide front end for my 87 FXR from demoncycles.com. One thing to keep in mind is ANY change of your front forks from stock, will change how your FXR handles. I'm not into carving up curves while riding, so a wideglide front end suites me well, and I love the look. It's up to you better looks, or better handling!
I like the way the lines run down the back of her stockings
bkrhoades is offline   Reply With Quote
Old 10-05-2009, 09:03 AM   #3 (permalink)
Ol' Biker's Avatar
Wide Glide Front
Thanks for your info & thoughts. I checked out your front end on Demons, very nice! (But too pricey for me.) I'm pretty much a cruiser-type rider so I think I can get along with a Wide Glide style front too. I've ridden old Wide Glides in days gone by and didn't have any trouble getting them to go where I pointed them based on my riding style, so I'm after the "look".
Old 10-05-2009, 09:17 AM   #4 (permalink)
Ol' Biker's Avatar
97 Dyna Wide Glide Front On A 84 FXR?
Well, I spotted a 97 Dyna Wide Glide front take off for sale (see pics). Guy says it'll bolt right on my 84 FXR but I'm not so sure... If anyone knows yay or nay, I'd appreciate your reply. Thanks!
Old 10-11-2009, 04:04 PM   #5 (permalink)
tegfxr's Avatar
tegfxr is on a distinguished road
I bought a nice chunky mid glide kit for my FXR and it looks the dogs danglies , uses same forks wheel etc bit kit comes with triple tree's and wheel , mudguard spacers etc . can send pics if needed to see what it looks like . certainly more standard looking than a wideglide kit imo !
tegfxr is offline   Reply With Quote
Old 10-13-2009, 09:31 PM   #6 (permalink)
blackjackcustms is on a distinguished road
Most wideglides need a 'lil trimming, before they'll bolt on an FXR. The forkstops usually. The only way to know is to try it. Personally, I just add a steering damper and a fork brace to my 39mm narrowglides, and play with the springing and damping. But I get the whole looks thing, too.
blackjackcustms is offline   Reply With Quote
Old 10-18-2009, 02:06 AM   #7 (permalink)
Ol' Biker's Avatar
Thumbs up 84 FXR Mid Glide Front End Conversion?
Thanks for your feedback. Ya know, the more I think about it, it probably does make more sense going mid glide than wide. My 84 has the small 35mm fork legs so I'd have to get a set of 39's to make it worth while I guess. Unless I could find good used, I'd probably just go with a set of chrome aftermarket legs then upgade to dual disc's and a set of aftermarket 4 piston calipers to give me better stopping power too. My single disc is pretty anemic when it comes to stopping performance. I like the idea of the mid glide conversion and keeping my stock cast wheel. I think it would be a positive upgrade both improving the looks as you mentioned along with likely maintaining the nice ride and handling I've come to appreciate with my FXR. I've been hesitant and concerned that going wide with a 21" wheel is just going to screw things up in favor of more "modern" looks. Please reply to this thread or send me a private message which manufacturers kit you used? I'd really like to look into this. Thanks again!
Old 10-18-2009, 02:17 AM   #8 (permalink)
Ol' Biker's Avatar
Lightbulb 84 FXR Wide Glide Front Fit?
Thanks for your reply, I appreciate your thoughts and suggestions. I've now had a chance to look at some OEM wide glide triple tree's. Like you said, probably a little trimming to the fork stops to make it work. Honestly I'm not a canyon carver type rider but I think I'd be giving up too much in handling for the wide "look", so I'm probably going to go with a mid glide conversion instead. Thanks again!
Old 10-18-2009, 08:42 AM   #9 (permalink)
LADave is on a distinguished road
I'm in the process of switching from a narrow to a wide-glide at the moment, using after-market trees. The fork stops are a concern to look into.
Here's a shot of mine, I had to do a bit of grinding on the lower part of the neck to get a decent "swing" in the front end...
Another area to worry about is the "tab" for the fork lock. I had to bend mine down to mock it up. I ended up just removing the tab...
Everyone wants to go to heaven,
Nobody wants to go now...
1987 FXRS-SP
.005" over 80-Inch, Andrews EV27 Cam
S&S "E" Carb - Ultima Single Fire Ignition
Manley Stainless Steel Valves & Crower Springs
Ultima Single-Fire Ignition
2-into-1 pipe (might be an LSR)
LADave is offline   Reply With Quote
Old 11-05-2009, 08:05 AM   #10 (permalink)
mrmango345 is on a distinguished road
Wide or Mid Glide Conversion
I'm in the process of going with a Mid glide conversion. I previoulsy did the 21" front wheel and still handles the balls. In my humble opinion the Mid with 39 mm forks is more proportionate. I actually decided to rake it 3 degrees too, to look more like a low rider. That will probably change the handling a little bit, but willing to give it a shot. Let ya know how I make out.
mrmango345 is offline   Reply With Quote
Old 11-08-2009, 04:35 AM   #11 (permalink)
tegfxr's Avatar
good luck with the Mid Glide Kit mate you wont be disappointed
Old 11-08-2009, 11:27 PM   #12 (permalink)
Fartnokker's Avatar
Fartnokker is on a distinguished road
Um, I don't quite now what to say. Your FXR handles balls? Ewwww...
Danny
Black Betty
1988 FXRP
Fartnokker is offline   Reply With Quote
