I agree, Dave is right on the money about the pulley nut and seal.
I suggest that in addition to replacing all the seals while you are in there that you make sure you have the upgraded front pulley,nut,lock and spacer.
The old design used a single bolt that threaded into the pulley, the theory was that if the nut backed off it would contact the bolt head and stop.
What really happened was the nut would start to back off, contact the bolt head, shear off the bolt and then continue to loosen.
The new design uses a lockplate that goes over the pulley nut, held by 2 bolts. The pulley is also thicker in the center web area making it stronger, and the spacer has a narrower width due to the wider pulley center.
