I have a buddy that is installing a V~Thunder EVL-3000 next week into his 2000 FXR4. The EVL-3000 features a intake close angle of 34 degrees compared to that of the EV-27 which is 36.
I have been running the EVL-3010 for 5 years and will be modifying my 99 FXR2 to the EVL-3000 this winter. (Heck for only $100.00 and some gaskets it worth it to play) I believe that moving the intake close angle from 39 which is what the EVL-3010 is to an intake close angle of 34 which is where the EVL-3000 is will be a nice little improvement for the lower end torque helping the cam to feel as though you are getting on it more in the 2700 RPM range which has to do with cam reversion.
Is that enough to make that much difference compared to the EV27 only you can determine that....the cost for the EVL-3000 is around $100.00 without the gear.
I definitely agree with the reflections above that modifying your exhaust away from the 2.5 true duals will help CONSIDERABLY!!!!
CLICK HERE TO READ ABOUT THE V~THUNDER CAMS
Regards,
"Classic"
