BikeBandit Leslie Kay'sStainless Ride Specialty Accessories
Dan Vance RacingMotorcycle.com Classifieds!
Leslie Kay's
Old 06-27-2009, 07:10 PM   #1 (permalink)
CherokeeSr is on a distinguished road
Evo FXR Oil Pressure
What oil pressure does your engine produce at idle on a 90+ degree day after it's well warmed up? Mine doesn't move the oil pressure needle at idle but reads fine when running.
CherokeeSr is offline   Reply With Quote
Old 06-27-2009, 07:50 PM   #2 (permalink)
Zero...So I took the gage off 20 years ago...
Old 06-28-2009, 01:02 AM   #3 (permalink)
Sarge7's Avatar
Sarge7 is on a distinguished road
HD book says 20-38 psi - if your idle is set below 850 rpm your pump isn't putting enough oil where it needs to be. The bike sounds good chugging at 850 or below but you won't be doing yourself or your bike any favors by letting that happen.
Sarge7 is offline   Reply With Quote
Old 07-17-2009, 05:46 PM   #4 (permalink)
NHFree1's Avatar
NHFree1 is on a distinguished road
I was in heavy traffic today and it was about 80 deg out. Not a lot of movement to get air moving across the engine. I was seeing my pressure at idle dropping right down to 10psi or even a little lower.
I'm sure the oil makes a difference too. I'm running Amsoil.
"To sit back hoping that someday, some way, someone will make things right is to go on feeding the crocodile, hoping he will eat you last - but eat you he will." – Ronald Reagan
NHFree1 is offline   Reply With Quote
Old 07-18-2009, 01:42 AM   #5 (permalink)
84FXRP is on a distinguished road
Welcome to the Forum!
Depends on the mileage. My 1984 Evo at 100,000 miles at idle on a hot day would read about 2 lbs. (At higher rpm the pressure came up.) The bike ran fine, but it was disconcerting. Given the motor has roller bearings (vs pressure bearings) they need good lubricant volume but not as much pressure as a sleeved bearing.
The OLD Harleys had total loss oil systems with oil supplied by a hand pump. On the "fuel" tank, one side was gas, the other side was oil. (Stylistically we see more modern HDs reflecting this heritage with twin "gas caps" - one real - one fake or a fuel gage.) When the engine began to rattle around too much, it was time to squirt some more oil in the top of the engine and let it trickle its way down.
Bottom line, yes you should rebuild it someday. But as long as you have good oil volume flowing and no unusual noises, I just would not be in a panic to tear it down.
84FXRP is online now   Reply With Quote
Old 07-18-2009, 07:02 AM   #6 (permalink)
plugeye is on a distinguished road
haha, great advise. plenty of more important stuff to be concerned with.
plugeye is offline   Reply With Quote
