Did you find all the loose parts of the lifter that went into the engine?
Make sure you have every little piece of debris, or it will come back to haunt you in a very expensive way...
If you found all the debris, you can replace the cam and lifters and you will be ok.
The early EVOs had lifters that were known to fail, at the roller.
Sometime in the mid `90s they changed the design of the lifter.
The lifters that you can get from the dealer are the upgraded “B” lifters, they are very good units.
