Hey all - got another question for ya. I am replacing the oil lines on my fxrt, and am a bit confused as to which fitting on the oil tank is for what. When I pulled the old lines off of the bike, this is how they were run:
- Outer (right-most fitting) - from crankcase to oil tank (vent)
- Middle - from oil filter to oil tank (vent)
- Inner - from oil tank to oil pump
My Service manual has a diagram like this:
- Outer - from oil filter to oil tank (vent)
- Middle - from crankcase to oil tank (vent)
And the parts manual shows this arrangement:
- Outer - from crankcase to oil tank (vent)
- Middle - from oil tank to oil pump
- Inner - from oil filter to oil tank (vent)
Now, I'm guessing the parts manual is wrong, as the oil outlet to the pump was on the inner fitting, and the engine would have died by now if it wasn't getting any oil. I also looked inside the oil tank, and the vent lines on the inside are on the outer and middle fittings, so the inner fitting has to feed out to the oil pump. I'm not sure which vent fitting is supposed to be which, or if it even really matters - if they're both vent inlets to the tank, would they work the same whether connected to the oil filter or the crankcase? Maybe I'm making a mountain out of a mole-hill here - LOL. Just want to make sure I'm getting the connections right. Thanks
