FXWG rebuild - Page 2 : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Model Specific Discussion Forums > Harley-Davidson FL/FX
Old 11-14-2016, 04:45 PM   #16 (permalink)
Jehu wants to know Dino or Syn?
More for powder coating. I really didn't want to take the engine down but I think I'll be glad I did.
Jehu is offline   Reply With Quote Quick reply to this message
Old 11-15-2016, 12:49 PM   #17 (permalink)
Master Motorhead
Thermodyne's Avatar
Thermodyne is still riding a stock bike Thermodyne is still riding a stock bike Thermodyne is still riding a stock bike
Don't powder coat the jugs. Powder coat is one of the worst coatings for parts that radiate heat.
Cold oxide them with copper selenium compound, then hit em with a light clearcoat.
Thermodyne is offline   Reply With Quote Quick reply to this message
Old 11-27-2016, 05:15 PM   #18 (permalink)
Soda blasting works a lot better than I was expecting.
It took less than 30 seconds to clean half of this intake.
ID:	214778   Click image for larger version
Old 01-04-2017, 01:11 PM   #19 (permalink)
Building up my tool collection...
ID:	216289   Click image for larger version
Old 01-04-2017, 02:13 PM   #20 (permalink)
Alan S's Avatar
Alan S is still riding a stock bike Alan S is still riding a stock bike
Excuse me while I drool.
What is freedom of expression? Without the freedom to offend, it ceases to exist.
Salman Rushdie
Rules read.
Alan S is offline   Reply With Quote Quick reply to this message
Old 01-04-2017, 02:49 PM   #21 (permalink)
New wheel came today. Kind of expensive but it's hard to find dual flange Wideglide spokes.
I'm having trouble figuring out what kind of jug this is. Does anyone know?
ID:	216305   Click image for larger version
Old 01-10-2017, 01:25 PM   #22 (permalink)
Polishing is a lot of work. I'm halfway done with the rocker boxes. Then I can get started on the dry primary cover, the cam cone, the forks, etc. I'm going to be at this a while.
Name:	20170109 ROCKER BOX.jpg
Old 01-10-2017, 01:27 PM   #23 (permalink)
I like the result of powder coated jugs and soda-blasted heads.
Old 01-11-2017, 06:47 PM   #24 (permalink)
A little too much effort maybe. The rear tank mount gusset didn't sit down on the frame so I needed to fabricate a raised mount. I used a semi circle of tubing and a threaded bung. I didn't like the front mount. It was just a bolt going through the frame with a nylon nut. I thought it would be a cleaner finish to drill and weld bungs. Unfortunately, no shop in town carried threaded bungs so I took some larger ones that I had and borrowed a friend's lathe. I ground the frame down about 1/8" on both sides and drilled out for the modified bungs. It was most of a day's work but it looks much better I think.
ID:	216673   Click image for larger version
ID:	216681   Click image for larger version
Old 01-12-2017, 04:05 PM   #25 (permalink)
I've been having a bugger of a time with identifying the pistons for rings. The bore was checked by the machine shop to be 3.657" so I concluded that I have 3-5/8" bored 030 over. That's easy enough until ordering rings. There's more to ring specs than cylinder bore. The previous owner assured me (twice) that they're S&S pistons. Over on the HD forum, I got 3 people telling me that S&S never stamped the bore overage on the top so they can't be S&S. I called S&S tech support and he agreed with them but told me that I should be able to find ID on the bottom inside. I tried taking pics and, viola, S&S pistons with unusual stampings. Whodathunkit?
ID:	216770   Click image for larger version
Old 01-12-2017, 04:08 PM   #26 (permalink)
I got my front tire today. It's an Avon Speedmaster. From what I've been gathering from other conversations, I'll probably go through a common cycle of running the nostalgic bias ply tires until they're worn enough to rationalize something more modern and then swearing off of bias ply tires for life. YOLO
Old 01-12-2017, 05:05 PM   #27 (permalink)
Alan S's Avatar
Great build. Keep us updated.
Salman Rushdie
Rules read.
Old 01-17-2017, 05:58 PM   #28 (permalink)
The nose cone polished up nicely. Only took about an hour trying different wheels and compounds.
Old 01-25-2017, 01:04 PM   #29 (permalink)
Not taking any chances. Here's the array of Loctite as recommended by HD:
Old 01-25-2017, 01:10 PM   #30 (permalink)
Master Motorhead
Thermodyne's Avatar
I don't see any primer. And you might want to pick up a tube of ThreeBond.
