Diamond Bar ChoppersMBO EnterprisesMotorcycle-CommunicationLeslie Kay'sSportbikeTrackGearAdvanstarMotorcycleShowsDan Vance RacingBikeBanditProCharger.comCustom DynamicsAmerican Side Road Cycle
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > General Discussion Forums > Harley-Davidson FL/FX
GoFreeCreditReport
Old 10-22-2009, 04:06 AM   #1 (permalink)
jmac851 is on a distinguished road
Belt installation on shovelhead
If I install a belt for the primary on my 1973 shovelhead, how do the clutch basket bearings get lubrication?
Jim
jmac851 is offline   Reply With Quote
Old 10-22-2009, 10:01 AM   #2 (permalink)
Smuggler
Jim
You install a sealed bearing. I did that to my 72 FLH. Also If your going to maintain a normal sealed primary you should make sure to vent it.
Old 10-22-2009, 01:45 PM   #3 (permalink)
02 RK,S&S 124" Evo
dog155's Avatar
dog155 is on a distinguished road
I used to use heavy grease,and service it often
06 RK,155" R&R TwinCam
02 RK,124" S&S Evo
dog155 is offline   Reply With Quote
Old 10-22-2009, 02:57 PM   #4 (permalink)
DILLIGAF
berserker's Avatar
This might get more responses in the shovelhead or primary/clutch section.
Old 10-22-2009, 04:18 PM   #5 (permalink)
Smuggler
Most Kits
Most belt drive kits for shovels now include the sealed bearing
Old 10-22-2009, 07:29 PM   #6 (permalink)
ShovelheadBill is on a distinguished road
If you're running the stock setup, technically you’ve got a dry clutch and those bearings don’t see a lick of lubrication (at least from the oil in the primary) anyway. The only lube they get is from the grease you put on them during routine maintenance.
ShovelheadBill is offline   Reply With Quote
