RRcycles.comDan Vance RacingFuel MotoMotorcycle.comCustom DynamicsProCharger.comCycleGear.comMotorcycle-CommunicationDiamond Bar Choppers
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > General Discussion Forums > Harley-Davidson FL/FX
R&R Cycles
Old 08-20-2009, 12:31 PM   #1 (permalink)
schaffersshovel is on a distinguished road
conversion info 75fxe
hi i need some info on my progect im doin 4-6 speed swap on my 75fxe ,i purchased trans used from freind allready and im aware of the kits that are aval,,,,man i got 3 kids 1 in collage that been said dont wanna waste $$$$ on **** i wont need ,oiltank&battery box mods done,now trans plate im thinkin the o.offset 5spto4sp frame one vulcan#3541,then get the belt drive kit from jeirh#58-730 ,ill need starter but thats strait forward,have newer style cluch handle ,but may go hyd,any body do this whith out buyin kit for 3000.and if so little help on proper parts ill need, ill be sellin my pri set up (internal dry belt),trans,starter,and other stuff ,any input ???? thanks
schaffersshovel is offline   Reply With Quote
Old 08-20-2009, 01:13 PM   #2 (permalink)
springer-'s Avatar
Your description of the transmission is not clear. Is it a 6 in a 4 conversion transmission or is it a Softail 6 speed? If it is a softail 6 speed it will be LOTS of trouble to fit in the 4 speed frame.
I'll assume for now that it is a 6 in a 4 conversion transmission......
I don't think you will need the transmission plate listed. If I am not mistaken that tranny plate adapts a regular 5 speed softail transmission to a 4 speed mount. The conversion transmission you are looking at should already have the correct mounting pattern to fit a standard 4 speed tranny plate.
I am not sure about the part number for the belt drive. I looked it up but the description is vague. The picture with the description is a softail beltdrive and if that part number is for a softail, it will not fit either. Again assuming you are using a 6 in a 4 conversion transmission.
If you are using a softail transmission, then ignore the above two paragraphs and expect LOTS of modification to get any thing to fit right.
207-621-8089
Old 08-20-2009, 03:23 PM   #3 (permalink)
springer
thanks ,it is softail trans coverin years i mention and i have (new blood for swingarm frames) you aware of this? the trans plate looks simaller to 5in to4 plate? now ,intininater kit from karata says slite mods to case (softail trans)im aware of these mods ,so now belt kit i mentioned ,cluch drum should work ,sproket shaft pully,i think theres a dif,in diamiter?? sorry bout spellin bear wit me
