Originally Posted by ktwillys
given what was said by atrick if your lines are good and they probably are..
you still have air in the system... you may have gotten the majority of the air out of the caliper but you still have an air bubble at the master cylinder fitting. this happens all the time..
wrap a towel around the bars and cover the rest of the bike with something that the fluid cant get through and then pump up the front brake and crack open the banjo bolt at the master cylinder and get the air out..
make sure you have the handlebars turned so that the banjo fitting is at its highest point ......
Thank you sir, I'll try that. The bike has been this way since new, but I'll try anything at this point.
I asked the owner why he didn't complain to the dealer after he got it, and he said he thought it was supposed to be this way......
I'll let you know how it turns out.
