I recently bought a 76 fxe.Came with fat bobs and an older mikuni carb. Carb is about an inch too tall,makes contact with tank. Anybody else run into this problem?
I had the same problem with my 5 gallon tank's and my oricinal S&S carb.I ended up denting the tank in where it came in contact with the air cleaner. Of course it was'nt enough so I then ground away a bit of the air cleaner and that did the trick.
When I got a "New" S&S Super E , it cleared the tank's just fine.
Springer Dave
'73 Super Stroker Hydra Fat Soft Low Bagger Spring Glide Shovel
