Annoying Vibration : V-Twin Forum: Harley Davidson Forums
Old 11-25-2006, 04:32 PM   #1 (permalink)
easyflyer65 wants to know Dino or Syn?
Annoying Vibration
I too have been experiencing that good 'ol Dyna vibration - like trying to hold on to a sawzall cutting through pipe! It seem's like it's getting worse. I've tried it all - new front and top mounts, HD alignment proceedure, Balance Masters, Hayden M6, re-jetting, different pipes, even tried the $10 fix on this forum - no improvement. My question is, has anybody had a bad REAR motor mount? During the HD alignment procedure, does it make a difference which MOUNT and which BOLTS get tightened up FIRST? Thanks.
easyflyer65 is offline   Reply With Quote Quick reply to this message
Old 11-25-2006, 05:41 PM   #2 (permalink)
Screamin'XL wants to know Dino or Syn?
According to the HD manual, torque the frame to mount bolts first and then torque the engine to mount bolts. Don't think it makes much difference, but just wanted to give you the heads up. I would definitely check the rear mount just to be on the safe side. How many miles on the bike?
Screamin'XL is offline   Reply With Quote Quick reply to this message
Old 11-25-2006, 07:50 PM   #3 (permalink)
Only 8k, I just replaced the front about 300 miles ago. Went out for a ride today, vibs so bad I turned around and came back home, got out my Suzuki ATV - it's smooth. I don't care what anybody says, if you spend $14K for a motorcycle excessive vibs shouldn't be "normal". Thanks.
Old 11-25-2006, 09:14 PM   #4 (permalink)
route66paul's Avatar
Have you checked your tires? Do you have spokes? It could be a bad or out of balance tire, an untrue rim and bad wheel bearing, swing arm rear shocks, it goes on and on. Find a good indie, they will find it before the dealer will.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 11-26-2006, 12:42 AM   #5 (permalink)
My front tire was a bit cupped so I put a new Metzlers on, no differrence. The vibs are rpm related, pull in the clutch at speed and they go away. Vibs really bad when decelerating to a stop, and also bad sitting still. Wondering if something in the clutch/tranny could cause this?
Old 11-26-2006, 12:45 AM   #6 (permalink)
I'm Paid Up...
DR_DEUCE wants to know Dino or Syn?
I know you have the M6, but I minimized the vibration on my DWG by tightening the primary chain to the tight side of spec.
DR_DEUCE is offline   Reply With Quote Quick reply to this message
Old 11-26-2006, 04:14 AM   #7 (permalink)
rcm
HOG Member
rcm wants to know Dino or Syn?
I had some vibration on my 06 FXDI (6500 miles) after having new tires put on at the dealer. I returned the next day and asked them to check it. After two test rides and a real good look they disovered a torn front engine mount. Replaced under warranty and the vibration is gone.
rcm is offline   Reply With Quote Quick reply to this message
Old 11-26-2006, 08:49 AM   #8 (permalink)
I'm primary chain fairly tight. I took out the M6 and put the stock tensioner back in, then put the M6 back in, no difference. I had my bike into the dealer in July, wanted them to check out EVERYTHING, the said vibs are normal and charged me .5 hrs labor. Obviously they didn't look at nothing.
Old 11-26-2006, 12:14 PM   #9 (permalink)
Acquisitions
dynageno's Avatar
dynageno is reading this now saying WTF is this?
Sounds like a very perplexing problem! Check out that rear mount. Let us know what you find. I sure want to know what it is being a Dyna rider-thanx...
Back in Black
dynageno is offline   Reply With Quote Quick reply to this message
Old 11-26-2006, 08:03 PM   #10 (permalink)
Oldandslow wants to know Dino or Syn?
This won't help you any but i have the same problem on my 07 Super Glide. I asked the dealer if it was normal to shake like that and he said it was. It's especially bad when i pull in the clutch and am slowing down. Some where between 2000 and 1000 rpm it shakes like crazy. Also at idle. I'm just going to use lots of blue loctite and ride it until it falls apart!
I wonder if I could trade it in on a counter-balanced "96" "Soft Tail" for a few thousand dollars? Is the counter-balanced engine a lot smoother?
Oldandslow is offline   Reply With Quote Quick reply to this message
Old 11-26-2006, 08:19 PM   #11 (permalink)
Looking at the rear mount it doesn't move at all but this is probably due to the fact that it act's like a pivot point - front mount does all the movin. I'm wondering why I don't feel much vibration when excelerating hard. Anybody notice this? I guess I could change out the rear mount and see what happens.
Old 11-27-2006, 08:39 AM   #12 (permalink)
1969K10 wants to know Dino or Syn?
I fought what turned out to be a broken motor mount for several months. I was told it was everything from the neck bearings, to the wheel, tire, drive sprocket, brakes, and a few other things...
Mine was OK under acceleration. on maintaining speed, there was a noticable vibration, but nothing bad. however, when I was stopping, it was BAD! There at the end it was so bad I didn't enjoy riding the bike much.
Turned out it was a broken motor mount, so if your suspecting them, pull them off and check them!!!
1969K10 is offline   Reply With Quote Quick reply to this message
Old 11-27-2006, 09:29 AM   #13 (permalink)
klinkcol wants to know Dino or Syn?
06 FXDI with over 18K. Vibration between 60-70 MPH in Sixth gear. It vibrates in all gears, just at lower MPH. It is RPM related. Pull in the clutch and the vibration goes away. The vibration got real bad around 5K. HD replaced the front motor mount and reduced the vibration back to where it has been. Also shimmed the front motor mount, which helped a little. The transmission main shaft bearing has been replaced twice, due to excessive noise. It seems to go bad at 7K intervals.
klinkcol is offline   Reply With Quote Quick reply to this message
Old 11-27-2006, 11:04 AM   #14 (permalink)
Tom T's Avatar
Tom T wants to know Dino or Syn?
Vibration
I heard from different sources that the B engine has more vibration at higher RPM's then the none balanced at cruising.
2004 Dyna, Stock Modified
Tom T is offline   Reply With Quote Quick reply to this message
Old 11-27-2006, 09:08 PM   #15 (permalink)
Went for a ride today, couldn't take it no more. Pulled the bike in and checked the mounts AGAIN, nothing looks wrong. Just doesn't make for a good ride when you know something isn't right. I was going to build the motor after x-mas but I'm thinking about selling it. Never buy one again.
