Dan Vance Racing
Old 09-01-2005, 12:17 PM   #1 (permalink)
baroth1 is on a distinguished road
front turnsignals on the rear
It's not really a Dyna question, but can a guy simply plug front turnsignals into the spot where the rear turnsignals go and have rear running lights?
Also, what year HD's have the tail light lens and reflector as one piece?
I have extra front turnsignals and if this would work (with a minimum of cutting and splicing) it would save me the cost of one of the add on running light conversions.
Thanks,
BAR
If you want to blend in, ride the bus...
http://tinyurl.com/26x2w2
http://tinyurl.com/25v8q4
baroth1 is offline   Reply With Quote
Old 09-01-2005, 12:49 PM   #2 (permalink)
TomB is on a distinguished road
Almost, but not quite plug-and-play ... you have to run a wire from the harness to the running light connection.
TomB is offline   Reply With Quote
Old 09-01-2005, 12:50 PM   #3 (permalink)
Cop_Stanger's Avatar
Cop_Stanger is on a distinguished road
The rear turn signal plug is a 2 wire. I did what you want to do by using the 2 original wires where they go and then running the 3rd wire to the aux plug behind the tail light for running lights. I used the 3 wire connector and put 2 leads in the running light port with some connectors and then put connectors on the running light wires coming from the lights and just connected them to the leads coming from the plug. It works great.
Here you can see the left signal flash with the right running light lit. Now when they flash the running light on the flashing light stays lit rather than using a module where the light goes out completely between flashes.
Run.
brake. Gotta love those www.heavycycles.com lights
Tom S.
2005 FXSTB
My photos:
http://public.fotki.com/ascmclaren/
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt" --Bertrand Russell
Cop_Stanger is offline   Reply With Quote
Old 09-01-2005, 03:50 PM   #4 (permalink)
Good information, Thanks!
As I see it I can have turn signals with either aux. brake lights or tail lights. That is while avoiding the cost of one of the "kits" on the market. Just have to decide which one makes the most sense.
BAR
Old 09-01-2005, 04:00 PM   #5 (permalink)
I also added the HD brake light module so I have run, brake and turn signals just like a car without separate signals would have.
Tom S.
2005 FXSTB
My photos:
Old 09-01-2005, 07:51 PM   #6 (permalink)
Speed
KLars1 is on a distinguished road
Run.
I really like your set-up and want the same for my 05 FXDWG. A few questions:
Did you or did you not install front signals into the rear position to accomplish this? I couldn't follow...
Did you have to install the load balancer as well?
Can you list all of the parts you needed for your set-up including the LED lights?
Thanks!
2002 FXDWG3 Navy
KLars1 is offline   Reply With Quote
Old 09-02-2005, 05:22 AM   #7 (permalink)
Thanks!
www.heavycycles.com 3 wire LED turn signals, same as fronts but with red LED's.
www.biketronics.com load equalizer for the LEDs, plug and play into the harness under the seat.
Harley Davidson Auxilary brake light/turn signal conversion kit, the older one that adds just brake light function to the signals plugged into the same harness under the seat.
Tom S.
2005 FXSTB
My photos:
Old 09-02-2005, 11:24 AM   #8 (permalink)
Datawave is on a distinguished road
Lights
Great post Cop Stanger......thanks
Datawave is offline   Reply With Quote
Old 09-02-2005, 04:19 PM   #9 (permalink)
I need to clarify something. My bike was away from home when I posted this and now that it's back I see that the housings are different. But, the innards are changeable between them. Just pull the bulb out and then you'll see a couple of slots, use something to hook them and gently pull the reflector out of the rubber, I just did it on an old set and it pulls out fairly easy and then you can put the 3 wire innards in the rear housings.
Tom S.
2005 FXSTB
My photos:
Old 09-03-2005, 02:30 PM   #10 (permalink)
Speed
What is the advantage of this approach over using 2 wire rear signals with the TailBones module?
I'm assuming its cost...$45 for the H-D module and some extra wiring compared to $110 for the Biketronics TailBones.
thanks,
Kevin
2002 FXDWG3 Navy
Old 09-03-2005, 02:43 PM   #11 (permalink)
thanks,
Kevin
I tried the Tailbones unit with the LED's and they were so bright that it looked like the brake lights were on all the time. My buddies hated them and wouldn't follow me anymore, I was stuck in the back. And besides, with that setup the light just goes out to blink whereas mine go dim between blinks and look entirely factory installed.
Tom S.
2005 FXSTB
My photos:
Old 09-05-2005, 01:28 PM   #12 (permalink)
Speed
Interesting...dd the brightness of the stop light go down when you switched from the Tailbones to the H-D? Or did just the brightness of the running lights go down?
Thanks again for all the info...Kevin
2002 FXDWG3 Navy
Old 09-05-2005, 01:45 PM   #13 (permalink)
I replaced the tailbones with the 3 wire setup but still use the HD unit for brake lights. The tailbones were to make the turns into running lights and brake lights but it made the running lights too bright, thus the change to 3 wire lights to get stock like running brightness and better than stock brightness with brake lights due to the LEDs.
Tom S.
2005 FXSTB
My photos:
