Swingarm mods : V-Twin Forum: Harley Davidson Forums
Old 07-26-2005, 08:06 AM   #1 (permalink)
Dyna Gaz1 wants to know Dino or Syn?
Talking Swingarm mods
Would it be possible to fit a v-rod swing arm on a dyna fxdx 2000 which has a chain conversion on??
I know this is a daft question i was just wondering if it has been done.
If so have hard it would be.
Cheers Dyna Gaz
Dyna Gaz1 is offline   Reply With Quote Quick reply to this message
Old 07-26-2005, 08:47 AM   #2 (permalink)
Rockbiter's Avatar
Rockbiter wants to know Dino or Syn?
I'm betting you would need the entire swingarm isolator joint (basicly, the frame section the swingarm attaches to) or a reasonable facsimie. Weld it into the FXDX frame after removing the stock joint. Expect to fabricate new shock mounts too. Custom shocks may be required. Now, as to whether it would fit with a chain conversion, thats an entirely diffrent problem concerning the actual clearances and such.
Anything is possible with the proper application of high explosives.
Basicly, Have fun!
'04 TC103 FXD
SE 4.375" Stroker Crank
SE 3.875" Flat top Pistons
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE 6200 RPM Ignition module
SE Clutch spring
White Bros E-Z clutch release
LMR2 oil pressure spring
Rockbiter is offline   Reply With Quote Quick reply to this message
