02-10-2005, 09:48 AM
#16 (permalink)
01 FXDXT / 75 FLH
Bolts Already....
Originally Posted by Duoglide_62
As was mentioned, you can get a 150 to fit, but might have to turn the fender strut bolts around. I took the shocks off and lowered the bike 2-2.5" (max travel of the shock) on the jack to see if the bolts would touch. It looks like there's about 1/4" clearance on the brake side. The belt side had plenty of room.
The bolts are already turned due to the saddle bag bushings...it's the width of a hex head (3/8"?) high....as far as Tom's remark...I do not detect any special bracket on the inside of the fender for saddlebag support....
02-10-2005, 10:00 AM
#17 (permalink)
Maybe it's only on the 2002 and newer FXDXT's. I haven't looked under a 2001 fender. It's a flat metal brace supporting the rear of the fender, where the pin for the saddlebag push-button release sticks through the fender.
Buddy of mine upgraded his 2001 FXDXT to a 150 rear tire using a kit supplied by the dealer. Dunno what was in the kit besides a narrow drive belt.
02-10-2005, 11:23 AM
#18 (permalink)
01 FXDXT / 75 FLH
Saddlebag Locking Mech?
The pin you mention is just to lock in the saddlebags...I don't think it's very big...I'll look on the underside of the fender to make sure....I thought 2001's had the narrower belt already....hmm...more research
02-11-2005, 01:11 PM
#19 (permalink)
Can you put a 160 on a stock 05' FXDC ?
2005 H.D. FXDC
2003 Triumph Speed 4
LIVE TO RIDE ANOTHER DAY !!!
02-15-2005, 03:19 PM
#20 (permalink)
I put a 150 dunlop on the rear of my 2000 FXDX, it is not the T model, which the only difference should be the side bags, and Fairing. same frame, shocks etc...
The FXDX suspensions not the same bike as the other DYNA family of bikes.
Dual discs up front.
"My Heart is of a Warrior, My Soul a Master"
2000 FXDX
2 V4 Interceptors
NRA, DAV, Go NAVY ! !
07-26-2012, 05:47 AM
#21 (permalink)
OOOOH. Resurrect the dead!
But everyone yells "do a search"...so I did
01 FXDL Stock 130/90B16 ....so what size 150 do I want to get?
No rush. I have new tires on now but am doing my research now.
K.thx.
07-26-2012, 07:17 AM
#22 (permalink)
Whatever the stock size is for an 03. It's. 16" rim. I forget the width. FWIW I run a 17" 160 on my 03 that was a takeoff from a newer FXD and it's tight but fits.
FXDRYDR
2003 FXD
124"
S&S stuff.
Baisley Pro Street heads
+ Level 2 Mojo.
Badass pipe.
Torq Monster Motorworks
spec'd & built, extra "Special Sauce."
TQ & HP TBD and really don't care.
Stay tuned.
07-27-2012, 03:35 AM
#23 (permalink)
Tire size for Dyna
I have a 00 dx and a 01 dxt they both have the dunlap kt591 150 tire on them it fills the fender nicely the only thing I had to do was grind the bolt heads down.
hdrider98ci
08-18-2012, 09:53 AM
#24 (permalink)
2 weeks ago I installed a 150 Perelli Night Dragon on my 01 FXDXT. Plenty of clearance.
08-18-2012, 10:10 AM
#25 (permalink)
i've owned my 01 fxdx since new. it came with a 150/16 from the showroom. you could go 160 safely. the all other dyna's came with a 130, reason the fxdx would fit the 150 waas the turn signal bar near the taillight as apposed to mounted on fender struts. wires going thru the strut will get rubbed through with the bigger tire. my dad experienced this with his standard due to shop installing wrong tire. i now run a 180, but i've cut the struts off the frame, mounted a newer fender to some hand made struts and don't put anyone out back!!
 107" axtel terrorist
thundertek cylinder heads
cams= not woods....
super "D"
loud d&d
2006 fltr
95" all secondhand parts
2009 1125cr. rolling grins.
08-18-2012, 07:40 PM
#26 (permalink)
Did anyone ever consider that it is not the fender clearance that is the problem but the drive belt that might be too close to the tire if a wider tire is put on? I have my wheel off right now installing a new Michelin Commander 2 tire so I can't check it. It is a 160-70/17 stock size.
Ride Safely,
Ed
Ed in Jeffersonville, Indiana
2007 HD Dyna Wide Glide
85 VT1100C Honda Shadow
84 V65 magna
Journeyman Machinist
Certified Welder
MSF RiderCoach
Aircraft Machinist USAF (Ret)
Viet Nam Vet (U.S. Army)
Streetrod Builder/enthusiaist
Patriot Guard Rider, Disabled Veteran.
08-25-2012, 06:16 AM
#27 (permalink)
fatkat
Originally Posted by Gunslinger
I put a 150 under my 01 Wide Glide....That's definitely the max for it. Yours has a different fender, but it should still be the same....150 MAX. Stock is a 130 I believe.
It makes a big difference in the look though, more than I thought it would.
I don't have a shot of it straight on, but you can tell the difference in this picture. I can get a shot straight on for you if you want, let me know...
Tony
Man,,you got it together,i love the way you think and express it.
God Bless America
08-29-2012, 06:17 PM
#28 (permalink)
My '03 FXDX has a solid Duece 17" wheel with a 160 Venom, it sits close to the belt but has never rubbed.
2003 FXDX Superglide Sport
08-29-2012, 10:00 PM
#29 (permalink)
I put on A avon venom 160 on my 99" fxdx, and it is slightly rubbing the drive belt. mostly noticeable when "backing up"
99 fxdx-First Harley & lovin' it
08-31-2012, 03:56 AM
#30 (permalink)
150 Metzler 880 on my '02 fxdx-t and I have no urge for a 160. There is no need for it.
If I knew the way I would take you home ...
| Sponsored Links |
