What Are The Best Wide Glide Shocks? : V-Twin Forum: Harley Davidson Forums
Old 12-17-2004, 03:08 AM   #1 (permalink)
Katttfishh wants to know Dino or Syn?
I weigh 250# and I bottom out the stock shocks pretty easy. Need a better shock that will handle weight better.
Katttfishh is offline   Reply With Quote Quick reply to this message
Old 12-17-2004, 08:02 AM   #2 (permalink)
nidan's Avatar
nidan wants to know Dino or Syn?
My Vote is for Progressives . I weigh about 210 with out gear . I've ridden the 418's even 2' shorter and no bottoming and smoot as silk. On my FXDWG3 I have the low profile HD shocks ( 1" shorter) which are made by FOX , no bottoming , but the progressives ride smoother . Watch E-bay you can usually pick up a good deal there.
2007 103" Stage II/SERT/IDS/SE Oil cooler/V&H duals
Progressive Suspension Monotube/Touring Link
2009 FJR 1300
nidan is offline   Reply With Quote Quick reply to this message
Old 12-17-2004, 11:19 AM   #3 (permalink)
fxdwg2005 wants to know Dino or Syn?
I have heard nothing but good things about Progressive, and in particular the 440 IAS's... thats what I plan on putting on my WG
fxdwg2005 is offline   Reply With Quote Quick reply to this message
Old 12-17-2004, 06:12 PM   #4 (permalink)
Gunxddslinger's Avatar
Gunxddslinger wants to know Dino or Syn?
Another vote for the 440's. I've got them on my Road King and they're great. I have the HD "Profile Low" shocks (Made by FOX) on my Wide Glide though and they also work very well. I'm 200# so were close. No complaints with either one. They look similar as well.....
Tony
FRIENDSHIP IS LIKE PEEING ON YOURSELF. EVERYONE CAN SEE IT, BUT ONLY YOU GET THE WARM FEELING THAT IT BRINGS....
2008 FLHTCU - 2003 XL883C
Liberals keep saying Obama needs time.....I agree. 25 to life seems about right!!!!
If Obama and Pelosi were on a ship in the ocean and it started to sink, who would be saved??? AMERICA!
Gunxddslinger is offline   Reply With Quote Quick reply to this message
Old 12-17-2004, 11:16 PM   #5 (permalink)
AustinFXDWG wants to know Dino or Syn?
I'm 220#, and don't bottom, even with my wife on the back. So, let me ask you a dumb question, have you tried adjusting the preload adjustment on your rear shocks to position 4 or 5 vs 1 which is the way they come from the factory?
I second and third the suggestions for the Progressives is you want to replace the stock shocks. The 440s give a better ride, though I don't think there's much difference than stock in their ability to prevent bottoming as that is a function of the spring, not the shock.
AustinFXDWG
2013 FLTRU Road Glide - Gutless Cat and MadStad windshield
2012 Triumph Tiger800XC, too many farkles to list.
AustinFXDWG is offline   Reply With Quote Quick reply to this message
Old 12-17-2004, 11:24 PM   #6 (permalink)
How do you adjust the fuggin things? I looked at them and couldnt see how they adjust. I have Progressives on my old fxr.
Old 12-18-2004, 01:14 AM   #7 (permalink)
Registered User
Mike G(wah_wah_wah) wants to know Dino or Syn?
Lightbulb
You need a spanner wrench available at the local stealer. You turn the shock clockwise to increase the preload which makes them stiffer. Start at full soft and work your way up one step at a time.
I'm 250# and mine are in the second (one stiffer than full soft) position and I have no issues. When I take the OL, about 120# I put them in the stiffest position and again no problems.
If I were going to change I would go with the Progressive 440, they are the best.
Mike G(wah_wah_wah) is offline   Reply With Quote Quick reply to this message
Old 12-18-2004, 01:18 AM   #8 (permalink)
ibrowse wants to know Dino or Syn?
Progressive!
ibrowse is offline   Reply With Quote Quick reply to this message
Old 12-18-2004, 11:18 AM   #9 (permalink)
I will try this. Thanks
