The service loop of extra harness length is reached by removing the plastic access panel on the inside front of the rear fender. Remove the panel, cut the cable ties, and feed the wire into the rear of the frame while someone else pulls it out the front. The connecotres will come out of the front of the frame. It really helps to remove the rear wheel, or at least put the bike on a lift and let the swingarm sag so you can get your hand up in there to access the panel.
AustinFXDWG
2005 FLTRi Road Glide - 95", SE Flat-tops, SE-AC, SEPro Slipons, Bassani Power Curve True Duals, Dynojet PCIII, HD Oil cooler, Mustang Touring Solo saddle, Fog Lamps, and HogTunes Speaker. Now we';re cruisin'...
