Light bulb replacement questions : V-Twin Forum: Harley Davidson Forums
Old 09-01-2004, 10:47 AM   #1 (permalink)
RockSRQ wants to know Dino or Syn?
My 1999 Dyna Super has two bulbs labeled "K8 GE 199" (rear turn signals) and "K8 GE 198" (front turn signals and tail light).
Are these the same bulbs as a typical 1157 used in automotive applications?
There are some replacements available, and I've been told they are the same from salesmen... but need more info.
Any ideas?
Thanks.
Dan
RockSRQ is offline   Reply With Quote Quick reply to this message
Old 09-01-2004, 11:06 AM   #2 (permalink)
TomB wants to know Dino or Syn?
The rear turn signals are equivalent to 1156, the tail and front marker/turn are equivalent to 1157.
I replaced mine with krypton bulbs from the auto parts store, 30% brighter for about $4 each. Can't recall the part #'s off the top of my head, I'll try to remember to take a look at them tonight.
TomB is offline   Reply With Quote Quick reply to this message
Old 09-01-2004, 11:34 AM   #3 (permalink)
Thumbs up thanks
Thanks.
I am going to try the LED replacements from:
www.superbrightleds.com
Will let you know if you are interested....
Old 09-02-2004, 10:27 AM   #4 (permalink)
AustinFXDWG wants to know Dino or Syn?
If you go with the LED bulbs, don't forget the Load Equalizer. You will need it for the flashers to function correctly since the LEDs draw so much less current than incandescent bulbs. Some LED units have the equalizers built in. If not, you can find them in any of the major catalogs where they plug into the main harness for the front and rear turnsignals.
AustinFXDWG
2013 FLTRU Road Glide - Gutless Cat and MadStad windshield
2012 Triumph Tiger800XC, too many farkles to list.
AustinFXDWG is offline   Reply With Quote Quick reply to this message
