Dan Vance Racing
Old 07-03-2004, 08:27 PM   #1 (permalink)
DallasDyna
Off center front end
Why does my 03FXDWG handlebars/frontend/triple tree seem to be a slight bit "off center" when I ride. When riding straight, it seems I must keep my frontend very, (very) slightly turned to the right side. There is no vibration (turns or straight) , no uneven tire wear, no difficulty in stopping,...all in all a very good ride. I asked the dealer to address this issue twice and was told all is OK. Any ideas? Thanks and ride safe.
DallasDyna is offline   Reply With Quote
Old 07-03-2004, 09:36 PM   #2 (permalink)
old fart
stev1955's Avatar
stev1955 is on a distinguished road
I noticed it on my FXD also. I trued up the rear tire in the swingarm and helped some but you can still notice it a little. Rides fine and no unusual tire wear either. May be normal.
Steve
2002 FXD
USMC 73-77
http://www.v-twinforum.com/gallery/s...=1&ppuser=1428
"Hooters, hooters, yum yum yum. Hooters, hooters, on a girl that's dumb." Al Bundy
stev1955 is offline   Reply With Quote
Old 07-03-2004, 11:20 PM   #3 (permalink)
spgtti is on a distinguished road
dampeners
try replacing handlebar dampeners.aftermarkets sell stiffer ones.or just lock your front wheel onto a wall or curb and twist the bars the opposite way.simple!
spgtti is offline   Reply With Quote
Old 07-04-2004, 09:29 PM   #4 (permalink)
AustinFXDWG is on a distinguished road
Most times it is because the dash panel on the tank is not centered, and you use that to judge the centerline of the bike. Loosen the nut holding it, and you can move it around to center it easily. Less likley is the rubber dampers on the handlebar risers are twisted a bit in the top tree. Loosen the riser bolts, straighten the bars and tighten it all back up.
AustinFXDWG
2005 FLTRi Road Glide - 95", SE Flat-tops, SE-AC, SEPro Slipons, Bassani Power Curve True Duals, Dynojet PCIII, HD Oil cooler, Mustang Touring Solo saddle, Fog Lamps, and HogTunes Speaker. Now we';re cruisin'...
AustinFXDWG is offline   Reply With Quote
