Because some people have never seen this leak they will tell you that I am wrong and they are right.
I am right though as I have seen the EXACT same leak you describe MANY TIMES. Not only that, my 02 model has the same leak.
Here is what I know.
You have THE LEAK!
THE LEAK cannot be fixed by your local HD dealer. They will do up to six attempts to fix your bike. Guess what?
They cannot fix it.
Neither can you.
What is the problem?
Most likely it is case porosity somewhere.
THE LEAK is common enough on DYNA TC88s that you can bet a dollar that HD knows exactly where the oil is coming from but the chances that your dealer knows the fix or will even fix it if they DO know are very, very slim.
Might as well get used to it.
It is possible that you need to replace the main primary gasket. Harley has changed this gasket three times since 2002 so there is a leak issue in this area that they are trying to resolve. CAREFUL installation of the primary cover with the latest gasket might fix your leak if you are lucky.
Just don't be surprised to see the leak again just when you think it is finally fixed.
It is primary oil that you are leaking and I believe that it is case porosity in the outer primary that is the problem. Chrome or not.
I'll edit this to add that no doubt you do have leaking seals at the inner primary and probably the transmission shift shaft seal and output shaft seal.
If a seal replacement fixes your bike you are very lucky.
Let me guess, you have somewhere between 1200 and 2000 miles on your bike?
