Installed the 12" touring air shocks : V-Twin Forum: Harley Davidson Forums
Old 12-06-2012, 06:35 PM   #1 (permalink)
1HD1C's Avatar
1HD1C wants to know Dino or Syn?
on my FLD today.. had them on my wide glide last year and finally got around to putting them on the FLD.. put 10wt oil in them last year and they made a night and day difference on the glide..
already noticed that just like on the wide glide the bike sits about
1/2" lower... fully expect the ride to be much improved over the stock shocks..
2012 FLD
2016 FLHXS
https://www.facebook.com/groups/222510704871627/
1HD1C is offline   Reply With Quote Quick reply to this message
Old 12-15-2012, 03:58 PM   #2 (permalink)
dirtdobber's Avatar
dirtdobber wants to know Dino or Syn?
I have been thinking about doing this on my wife's wide glide.
dd
http://www.v-twinforum.com/forums/image.php?type=sigpic&userid=31936&dateline=1212505304
dirtdobber is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 01:47 PM   #3 (permalink)
1HD1C's Avatar
dd
you cant go wrong... best riding shocks for the wide glide out there in my book. on the FLD with the bags, all of my crap in them and the tourpack i am at 15lbs using 10wt oil, i need to drop it to about 13 and i think it will be perfect..
also if you do go this route you definitely need to change out the shock oil as the touring bikes come with 5wt which on the dynas due to shock angle isn't heavy enough, i found 10wt to be perfect on the wide glide and now on the switchback
2012 FLD
2016 FLHXS
Old 12-28-2012, 08:07 AM   #4 (permalink)
1HD1C's Avatar
longer ride follow up,
they work exactly how they did on the wide glide handling is not affected at all
and the ride is so S-M-O-O-T-H..... and bike is at least 1/2 lower than with the stock shocks, for us short people that is a major plus...
2012 FLD
2016 FLHXS
Old 12-28-2012, 11:58 AM   #5 (permalink)
benzrod wants to know Dino or Syn?
hi dirtdobber, did you retain the stock exhaust on the FDL? The air cleaner looked like it had been changed. How does the bike feel between 2800 and 3200 RPM, and if no bad vibration, how did you solve the problem?
benzrod is offline   Reply With Quote Quick reply to this message
Old 12-31-2012, 02:25 PM   #6 (permalink)
dbrow6272's Avatar
dbrow6272 wants to know Dino or Syn?
I have a very short inseam even though I am 6' tall. I had 11" shocks installed on my FLHTCU and also had the seat cut down and a gel pad inserted. Fits perfectly now. Never thought about changing the oil in them though. How is that accomplished?
Ride em hard and put em away wet!
dbrow6272 is offline   Reply With Quote Quick reply to this message
Old 12-31-2012, 03:21 PM   #7 (permalink)
Warrior72's Avatar
Warrior72 wants to know Dino or Syn?
Did you buy the shocks used? How hard was it to swap out the oil in the shocks? Did you do a write up on the install for the Wide Glide? Sorry for all the questions but I have considered doing this to my Super Glide.
Warrior72 is offline   Reply With Quote Quick reply to this message
Old 01-01-2013, 07:40 AM   #8 (permalink)
1HD1C's Avatar
bought the shocks off of another HD forum for $90 shipped, they are the 12" street glide shocks.. but they turn up on eBay all the time pretty cheap, you also want the later model shocks as they are designed to hold more air than early on, i believe 2006 was the change over year..
here is a list that someone compiled of part #s and sizes, makes it easier to shop the sites and eBay
54532-85 13"
54536-02A 13"
54540-93 13"
54565-09 FLH FLHT FLHR FLHTI 13" (G5E3-00)
54565-97 (A) FLH 13"
54565-97 (B) 13"
54565-97 (C) 13"
54631-02B Road king FLHRS or FLHX or FLTRX 12" shock pair "low profile"
54632-98 bagger 12" or 12.5
54635-09 12"
54661-02A Road King FLHR Street Glide 12" single shock "lowered"
54662-09 street glide 11.5"
there are many different ways to change the oil listed on various sites online but for me the easiest was to pull the fittings and hang them upside down on a slight angle, got 11oz out of one shock and 10.4oz out of the other.. the box they came in had oil residue in it so i assume that's where the other.6oz went. refilled each with 11oz of 10wt bel ray shock oil and as i said the ride has been amazing to say the least..
since my bags are removable instead of air lines i went with 2 separate schrader valves because i didn't want to see the lines with the bags off the bike, i picked them up at ace hardware for $2.99 each and they work great..
only other thing i can add is if you go the air shock route make sure you buy a shock pump that does 1lb increments so you can dial them in, a lot of the pumps listed on eBay
only do 2lb increments..
this is the one i bought nearly 2 years ago and it still works great
http://www.ebay.com/itm/Air-Shock-Pu...sories&vxp=mtr
2012 FLD
2016 FLHXS
Old 01-01-2013, 11:02 AM   #9 (permalink)
Warrior72's Avatar
Thanks for the information, the search begins.
Old 01-01-2013, 11:22 AM   #10 (permalink)
werdna65 wants to know Dino or Syn?
Originally Posted by 1HD1C View Post
i am at 15lbs using 10wt oil, also if you do go this route you definitely need to change out the shock oil as the touring bikes come with 5wt which on the dynas due to shock angle isn't heavy enough, i found 10wt to be perfect on the wide glide and now on the switchback
I quess my brain ain't working, why would the touring have lighter weight oil in them, wouldn't that make them rebound to easy. Do you know the weight of the oil in the 2011 touring shocks, thanks
werdna65 is offline   Reply With Quote Quick reply to this message
Old 01-02-2013, 01:47 AM   #11 (permalink)
dirtdobber's Avatar
FDL?
I have a SG and a WG or FLHXSE3 and a FXDWG
The wide glide has a vibration up to 2,500rpm but that's the cams
At 2,800 rpm's it will pull your arms out of socket, Well almost LOl
The AC is the open ac
The SG has the stock AC with K&N filter.
dd
hope this helps.
Old 01-02-2013, 06:58 AM   #12 (permalink)
scudda wants to know Dino or Syn?
I have been looking at doing the same thing on my 1995 FXDL. This just made up my mind!!
1995 FXDL
1998 Tin set in Sinister Blue
Bikers choice 12 inch HD Shocks
V&H Short Shots
Kuryakyn Mach 2 Air Cleaner
CV Carb with CV performance Kit
scudda is offline   Reply With Quote Quick reply to this message
Old 01-03-2013, 03:38 AM   #13 (permalink)
Gearhead
2wheelrider's Avatar
2wheelrider wants to know Dino or Syn?
Very good write up! thatks for the info!
2001 FLHTC 95ci Custom mtr hyd cam & 06up heads
welded btm & forged pistons to much to list. for sale.(SOLD)
2001 FXDXT (S&S SA 131ci motor)
2010 street glide..103ci 57 cams...fun and reliable...
2wheelrider is offline   Reply With Quote Quick reply to this message
Old 01-03-2013, 11:55 AM   #14 (permalink)
1HD1C's Avatar
it has to do with shock angle.. from what i understand ALL of the touring bikes come with 5wt and the only difference is the earlier models can only take 25lbs of air while the late model bikes can go to 50lbs
2012 FLD
2016 FLHXS
Old 01-05-2013, 02:23 AM   #15 (permalink)
Jbco2 wants to know Dino or Syn?
I have them on my 2011fxdb, they are the longer touting ones.
I did lots of trials to get them suited to my taste air pressure-wise.The idea was to have them while I waited from my custom shocks to get here.
Now, I think I am going to keep them.
Joe
Jbco2 is offline   Reply With Quote Quick reply to this message
