SE Compensator Gear Sprocket for 2005 Dyna : V-Twin Forum: Harley Davidson Forums
Old 10-06-2012, 04:58 PM   #1 (permalink)
DR.SCOTT's Avatar
DR.SCOTT is on a distinguished road
hey,
I was wondering if anyone knows what if any HD Screamin Eagle Compensator Gear Sprocket or other that will work?
I installed a 120R on my bike and was looking to replace the stock part if this is possible.Everything I have seen has been listed for the 2006 and newer bikes.someone else most have done this,but I can not seem to find exactly what I need to know.
Thanks, any help would be appreciated!
DR.SCOTT is offline   Reply With Quote
Old 11-02-2012, 11:00 PM   #2 (permalink)
toejoe is on a distinguished road
I just installed BDL screw type compensator on my 1999 TC 96" Wideglide. I was going from a 25tooth (stock) to a 24tooth(BDL part) to change my gearing thinkin it would be cheaper at primary than rear pully area. The 24t screw type compensator from BDL has only couple miles on it but I like it so far ...at less than $100 total cost.
toejoe is offline   Reply With Quote
Old 01-13-2013, 09:09 AM   #3 (permalink)
DR.SCOTT's Avatar
Sprocket
How has it been now that you have had it for awhile.Can you tell the difference and do you like the change?
Old 01-13-2013, 06:15 PM   #4 (permalink)
bigpete1's Avatar
bigpete1 is on a distinguished road
what are you trying to do ?gear it up or down ,if you are looking gear down installing 24t comp sprocket with 37t clutch basket would give 3.37 gearing raises rpm at highway speeds by couple rpm and motor will spool up alot faster .did you put crate motor in bike?thanks pete
11 fltriu 06 fxdi 03 flht 93 fxrs-sp
bigpete1 is offline   Reply With Quote
