dyna vibrations - Page 3 : V-Twin Forum: Harley Davidson Forums
Old 01-14-2012, 04:42 AM   #31 (permalink)
Galdog's Avatar
Galdog wants to know Dino or Syn?
I shimmed my mounts, made quite the difference. Still jumps around at idle, but levels out immediately when I take off. No more buzzing in the bars, etc. Then I added polyurethane bushings, Progressive springs up front and Progressive shocks, bike really rides well now.
2006 Street Bob
Galdog is offline   Reply With Quote Quick reply to this message
Old 01-16-2012, 09:10 AM   #32 (permalink)
Kevinmach1 wants to know Dino or Syn?
Originally Posted by 1HD1C View Post
while i agree it is a "HOG" as you put it there does seem to be excessive vibrations in some of the bikes with the 103".
my 11 wide glide vibes were fixed at the first service with a motor mount tightning
but i have since traded to a new fld and between 2900 and 3k
there is an awful vibration that DOES make my teeth chatter
i dont know how much higher in RPM it goes since i dont have my 500 miles yet but evidently the MoCo is aware of a major vibration
problem which is being looked in to.
im hoping they get it figured out before i get my 1k service done
You didn't happen to get the harley "stage 1 tune" from the dealer by chance? Mine didn't have the vibration problem like you described until after I had the dealership install the pipes, air cleaner and the special "tune" . I strongly believe its the tune that is making it run rough and causing the vibration.
I still have the vibration and I am looking into getting some dyno tuning done here in the near future. its a little hard to get done with it being the middle of winter..... I WILL get it smoothed out.
2012 Wideglide
Kevinmach1 is offline   Reply With Quote Quick reply to this message
Old 01-16-2012, 10:34 AM   #33 (permalink)
1HD1C wants to know Dino or Syn?
nope, she sits as she came off of the showroom floor.
1HD1C is offline   Reply With Quote Quick reply to this message
Old 01-16-2012, 11:18 AM   #34 (permalink)
Wow, OK. Well if you think it vibrates bad stock....Then DON'T get the stage 1 tune!!!....LOL
I am working with fuelmoto to get some tuning done, so there might be hope yet!
2012 Wideglide
Old 01-17-2012, 09:32 PM   #35 (permalink)
dhoward wants to know Dino or Syn?
Different motors on Dynas than slops. "A" Motor in Dynas, "B" (balanced) in slops.
dhoward is offline   Reply With Quote Quick reply to this message
Old 01-17-2012, 11:27 PM   #36 (permalink)
scowell's Avatar
scowell wants to know Dino or Syn?
check your motor mounts, dynas have problems with these, folks have put spacers in to help. Replacing the mounts helped both my vibration and ride a lot (mostly the front mount fails).
scowell is offline   Reply With Quote Quick reply to this message
Old 01-18-2012, 08:41 AM   #37 (permalink)
nothing to do with whether it has a stock tune or not, there is a problem
that is hit or miss along the dyna line dont know if its other models as i
havent searched on it yet but there is a major vibration right around 3k
Also im not going to do squat with mine until the 1k check up, did mention it to
my local service manager yesterday just to give him a heads up that mine is
one of the bikes with the 3k vibration and as i said before the MoCo is aware
of the problem and supposedly working on a fix which im hoping they have before my
1k service
Old 01-20-2012, 10:20 PM   #38 (permalink)
47nuk wants to know Dino or Syn?
Don't downgrade !! I traded in my Roadking for a new FXDC and really miss the heavier bike. I'll probably sell my SuperGlide this summer and pick up a used touring model.
47nuk is offline   Reply With Quote Quick reply to this message
Old 01-22-2012, 09:20 AM   #39 (permalink)
1k service
How do you know MoCo is aware of the problem and is working on a fix??? I can't find anything to support that.
I would think adding the balancing shaft would fix the problem... Why not just do that?
2012 Wideglide
Old 01-23-2012, 12:01 AM   #40 (permalink)
DagoFairings wants to know Dino or Syn?
Balince Prob
Hay I a shop isn SD and Own a 09 Dyna with a 151" motor when It was stock it did vibrate but now I put the big motor and weld the crank its as smoth as silk
DagoFairings is offline   Reply With Quote Quick reply to this message
