Jetting after Air Cleaner and Exhaust upgrade : V-Twin Forum: Harley Davidson Forums
Old 06-26-2011, 10:32 AM   #1 (permalink)
CurtO's Avatar
CurtO wants to know Dino or Syn?
Hi, I just installed a K&N High flow air cleaner and Exhaust to my 1996 Dyna Wide Glide (Evo Motor) It runs great but I'm not sure if I might be running a bit more lean. How does one know if jetting needs to be changed?
Thanks for any help you can give.
CurtO is offline   Reply With Quote Quick reply to this message
Old 06-26-2011, 10:38 AM   #2 (permalink)
WikkedWorkshop's Avatar
WikkedWorkshop wants to know Dino or Syn?
http://www.nightrider.com/biketech/hd_cv_mods.htm
This is just a suggestion but while your at it you may want to read through this some real easy mods to carb that will make it run much better they also have a section just for the fine tuning on this site they explain it pretty well hope this helps
09 flht
Axtell 107 cylinders CP pistons
Wood tw8, Lifters, & springs
Heads "street ported" by Dean Turk
What do I know I dont even use Amsoil!!!
WikkedWorkshop is offline   Reply With Quote Quick reply to this message
Old 06-26-2011, 10:39 AM   #3 (permalink)
Gaff wants to know Dino or Syn?
http://www.nightrider.com/biketech/hdbuildstage1_tc.htm
I can't remember all the EVO stuff but this site will point you where you want to go, good stuff in here.
Gaff is offline   Reply With Quote Quick reply to this message
Old 06-26-2011, 01:54 PM   #4 (permalink)
LowRiderCustom wants to know Dino or Syn?
If the bike runs well leave it alone. If it runs bad you need a retune, it's as simple as that.
LowRiderCustom is offline   Reply With Quote Quick reply to this message
Old 06-26-2011, 02:15 PM   #5 (permalink)
berserker's Avatar
berserker is still riding a stock bike berserker is still riding a stock bike berserker is still riding a stock bike
Your letting more air in and more air out, most likely running lean, if nothing else not optimally.
berserker is offline   Reply With Quote Quick reply to this message
Old 06-27-2011, 12:33 AM   #6 (permalink)
CurtO's Avatar
That's what I was thinking. Even if it's running good and there is a noticeable improvement, I had a performance cam put in last year and only now upgraded Intake and outgo. I'm pretty sure I'll need to get some more gas in the mix. Thanks for the links, I'll be reading up on them.
CurtO
Old 06-27-2011, 08:00 AM   #7 (permalink)
berserker's Avatar
I do like the Nightrider site. Plus there has got to be someone here with a similar set up. I am guessing, up one size on the slow and main jet, and see. Shim or bigger needle after that.
Also have you drilled out the mixture screw on the carb?
Old 06-27-2011, 09:29 AM   #8 (permalink)
59panhead wants to know Dino or Syn?
High from Denver.....Do a simple plug reading ride/test.....you will need a pair of gloves...and a spark plug socket....and a open highway....I would put in a pair of fresh plugs to start too !
go run the bike at 40 mph for a steady 4 miles or so.....grab the clutch and hit the kill switch and get off the road in a safe area.... dont idle to a stop....pull both plugs.....if there snow white....your lean....if there black....your FAT or to rich ....do the test again @ 70 mph
again...white lean....black rich.....if the plugs look a little tan to light brown your jets are pretty close to being correct in size ! If you hace the stock CV carb...there set lean from the factory.....you have a slow jet...that works at idle to about 45 the the main jet kicks in at higer rpm's....and speeds.....remember your motor needs fuel to to make power.....and lean is not good for your motors life!
If your running a cv carb dont waste your money on a new carb,,,,the cv can be worked over and can make 75-80 +hp ...go to CV Performance .com for all the parts you will need to hot rod your carb the right way good luck
59panhead is offline   Reply With Quote Quick reply to this message
Old 06-27-2011, 11:31 AM   #9 (permalink)
CurtO's Avatar
Thanks for the great info 59 Panhead, I'll try the plug read test. I am running a CV carb and will look into some of those mods. I'm sure I can get a bit more out of the setup I have.
Old 06-27-2011, 01:39 PM   #10 (permalink)
FXRS84 wants to know Dino or Syn?
great step by step. also check www.johnscvperformance
FXRS84 is offline   Reply With Quote Quick reply to this message
Old 06-27-2011, 07:44 PM   #11 (permalink)
rbearden56 wants to know where he is and how he got here
If you want a proven kit to properly tune you EVO motor check out the Dynojet web site. They make stage 1 kit for your bike. I did one on my Buell S3T with great results and a dyno run to check the results. The kit comes with plenty of jets to get the carb right and detailed instructions and the correct size drill bit as well. The installation will take an afternoon and as long as you read the instructions and take your time it is what you are looking for.
rbearden56 is offline   Reply With Quote Quick reply to this message
Old 07-01-2011, 11:24 PM   #12 (permalink)
bsanorton1 wants to know Dino or Syn?
I ordered my rejet kit from CV Performance after looking at all the kits out there. Some were cheaper some were twice as expensive. CVPerformance seemed to have the best kit for the money & good reading on their site....like the nightrider site as well. Just picked up a stone stock 05' FXDC and my 'stage 1' parts all came in this week. CV kit, Arlen Ness Big sucker and Rush slip-ons...can't wait to dig into it! Did it years ago on my FXR, easy to do.
74' Norton Interstate
74' Kawasaki H1
74' RD350
84' RZ350
00' Buell X1
02' Buell M2
05' FXDC
bsanorton1 is offline   Reply With Quote Quick reply to this message
Old 07-02-2011, 11:39 AM   #13 (permalink)
berserker's Avatar
I am not sure if I believe in kits. Jets, needles, and shims.
Old 07-03-2011, 08:16 AM   #14 (permalink)
How you making out? Did you check the plug colors yet? Any spitting thru the carb (sign of lean condition)?
74' Kawasaki H1
74' RD350
84' RZ350
00' Buell X1
02' Buell M2
05' FXDC
Old 07-03-2011, 01:53 PM   #15 (permalink)
the benefit of kits are they come with everything you need. I really hate it when I have to stop and go find parts in the middle of a project. Granted there are always extra things you don't use and have paid for but the convenience and a good set of instructions make it all worth while.
