87 Octane or 91 Octane for my Dyna? : V-Twin Forum: Harley Davidson Forums
Old 03-15-2010, 12:35 PM   #1 (permalink)
jcbii wants to know Dino or Syn?
When I bought my 1995 FXDL a few months ago, the previous owner said to use only 91 Octane fuel. However, I just bought a service manual for my bike, and it says to use 87 octane or higher. I'm wondering if there is something that I'm missing. Can I use 87 octane? Looks like I can.
jcbii is offline   Reply With Quote Quick reply to this message
Old 03-15-2010, 12:59 PM   #2 (permalink)
rickr01 wants to know Dino or Syn?
I've got a 98 FXD and I run premium. I've run 87 in it now and then when that is all that's available and it runs ok, but you may get some minor spark knock. I don't like any spark knock so I run the 91. You can also slightly retard the timing if you get minor spark knock and still want to run the 87.
rickr01 is offline   Reply With Quote Quick reply to this message
Old 03-15-2010, 01:05 PM   #3 (permalink)
84FXRP wants to know Dino or Syn?
Did the previous owner make any engine modifications?
Some modifications (e.g. increased compression) may necessitate higher octane fuel.
If no engine mods, then I would go with the Owner's Manual recommendation. However, if I recall correctly my 1984 Evo required premium gas. I know I ran premium in my 1995 FLT but I don't have the Owner's Manual available to me now to confirm it was required.
Over 12,000 miles, at 45mpg, you will use about 270 gallons of gas - at $0.25 per gallon difference that is less than $70. I would just run premium and not worry about it.
You don't say if your service manual is a GENUINE Harley-Davidson Service Manual SPECIFIC for your year and model. If it is, then that information would be correct.
84FXRP is offline   Reply With Quote Quick reply to this message
Old 03-15-2010, 01:18 PM   #4 (permalink)
The previous owner said he bought it new with the Screamin Eagle pipes (which I removed to put stock pipes back on). He didn't know if they did anything else, so I'm assuming no engine mods were done.
As for the difference, I guess you're right in that it doesn't matter that much regarding $$. But I also wondered if running 87 octane would do any damage.
The service manual is geniune Harley-Davidson. I bought it from a Harley Davidson dealer, and it cost me $70 (ouch!), so I hope it's authentic. On page 1-9, it says 87 octane or better and then refers the reader to Section 3 - which basically says the same thing, but provides more information regarding the types of fuel (methanol, ethanol, etc.).
Old 03-15-2010, 06:48 PM   #5 (permalink)
If you are not hearing spark knock you are not damaging the engine with the 87. You will run into some areas that only have 87. It's fine to run in a properly tuned motorcycle.
Old 03-16-2010, 01:51 AM   #6 (permalink)
What's spark knock? I'm hearing (and feeling) some sputtering when I accelerate. Is that what you're talking about?
Old 03-16-2010, 03:13 AM   #7 (permalink)
Patsplace wants to know Dino or Syn?
I have the 2009 owner's manual from Harley and they specify 91 octane fuel.
Pat
Patsplace is offline   Reply With Quote Quick reply to this message
Old 03-16-2010, 10:02 AM   #8 (permalink)
Spark knock (some describe it as pinging or detonation) is a metalic sounding rattle that occurs when accelerating mostly under load. Advanced timing and lower than recommeded fuel octane can cause spark knock, but obviously there are others. Under very heavy acceleration a little minor pinging for a second or two is not anything to be concerned about but constant Spark Knock which sounds like someone is in the engine throwing marbles around is not a good thing. In a fairly stock or lightly modified engine, (not a high compression engine) it is normal to hear a little spark knock under heavy acceleration when using lower octane fuels. Retarding the timing just slightly will take care of this but you will suffer a little loss in the seat of the pants acceleration feel. Rather than play the game or take the chances, I would just run the 91 octane. If she runs good on 91 with no noticable spark knock then all is well!
Old 03-16-2010, 11:27 AM   #9 (permalink)
Vern1's Avatar
Vern1 wants to know Dino or Syn?
Greetings,
With all the ethanol showing up at the pump, I would run premium.
Cheers,
Vern1
NRA Lifetime Member
1997 Stage II FXDWG - Yep, still going strong!
Riding rigid frames in the 70's gave me the back I don't have today!
Vern1 is offline   Reply With Quote Quick reply to this message
Old 03-17-2010, 01:36 AM   #10 (permalink)
Thanks for the info. I don't hear any pinging when accelerating, but it sputters some. I just had it tuned by a local shop, but I'm not really confident they did a good job. Anyway, I guess that's another story. As for spark knock, it sounds like I don't have that. I do hear some pinging when it's just sitting and idling, but I figured that was a pushrod or valve making that noise. I'm coming off a Suzuki, so I'm sure some of these noises will just sound strange to me for awhile.
Old 03-17-2010, 01:42 AM   #11 (permalink)
Originally Posted by Vern1 View Post
Greetings,
I try to run Chevron premium when I get the chance. But in all honesty, I can't really tell the difference in how the bike runs when I use 87 octane or 91. But I have to admit I've filled it with 87 octane when the tank was probably half full with 91 octane, so I don't have any real comparisons to make any conclusions. I was just surprised by my service manual said 87 octane.
Old 03-17-2010, 11:13 AM   #12 (permalink)
Just a kid at heart
wydeglyde's Avatar
wydeglyde wants to know Dino or Syn?
What is the difference in price? 35 cents a gallon?
So for a buck and a half (on a tank full) you are going to take chances?
Doesn't make any sense to me at all. I run best I can get in my 97 Dyna. If they have 92 thats what goes in.
12 Road Glide Custom
wydeglyde is offline   Reply With Quote Quick reply to this message
Old 03-17-2010, 11:52 AM   #13 (permalink)
NJ RIFF RAFF's Avatar
NJ RIFF RAFF wants to know Dino or Syn?
. Very good point!
"If I choose not to decide, I still have made a choice!"[/B]
08 FXDC
V&H Big Radius
V&H Fuel Pak
Stage1 A/C
Mini Apes
Sundowner Seat
Progressive 412 Shocks
Mini Tach
BLING-BLING-BLING
NJ RIFF RAFF is offline   Reply With Quote Quick reply to this message
Old 03-17-2010, 03:36 PM   #14 (permalink)
Originally Posted by NJ RIFF RAFF View Post
. Very good point!
I'm sold on using 91 octane, and that's what I plan to do from this point on. Just thinking about it, my manual (page 1-9) says "Usa a good quality leaded or unleaded gasoline (87 pump octane or higher)." What this probably means is that 87 would be the minimum, but use higher if available. At least that's what I'm going to assume.
But just for the sake of discussion - Let's say the manual said "Use 87 octane only". Is there a risk of causing performance problems or damage by using a higher octane? I was told many years ago that higher octane gas is not "better" gas, it just burns slower so there's no pinging or pre-detonation in high compression engines. So what would the effect be of using higher octane in a stock engine where the detonation is slower than what the engine was designed for?
Old 03-21-2010, 11:47 AM   #15 (permalink)
NO EFFECT, NOTHING, NADDA! Stop worrying, put in gas and enjoy the ride.
