best oil filter wrench : V-Twin Forum: Harley Davidson Forums
Old 12-19-2009, 02:34 PM   #1 (permalink)
bbqbrisket's Avatar
bbqbrisket wants to know Dino or Syn?
I could have put this out in a general forum question but every time I see an oil filter wrench advertised, there is some caveat about not OK for twin cams or has cut out to clear crank sensor or some other note of importance so, since I have a Dyna, I'm here.
What is the best oil filter wrench / easiest to use / non knuckle scraping / and of course price. I see one guy has a fancy tool he invented for a lot of money where you don't need a ratchet but what could be easier than using the ratchet. I also have seen folks go down to the auto parts store, get a standard one that fits the perimeter of the filter and make cut outs. I really don't want to hassle with that.
thanks
bbqbrisket is offline   Reply With Quote Quick reply to this message
Old 12-19-2009, 03:43 PM   #2 (permalink)
Fourcats's Avatar
Fourcats wants to know Dino or Syn?
U can get one at an auto parts store {take a filter with you}. It will not have the "cutout", {you will have to remove the CPS when changing the filter} but it won't cost $30.
Fourcats is offline   Reply With Quote Quick reply to this message
Old 12-19-2009, 04:29 PM   #3 (permalink)
buy a cheap strap style, they work on almost any filter used for the common stuff. No need to have cut out. Cost maybe 10 bucks. Just had to replace mine after 10+ years of use the strap finaly let go. Not bad for 10 bucks.
Old 12-19-2009, 07:45 PM   #4 (permalink)
road king 100 wants to know Dino or Syn?
thanks
use a K&N filter with nut welded on end of filter
03 RKC=GMR 117" build WITH S&S CYL. KIT
124HP/139TQ
road king 100 is offline   Reply With Quote Quick reply to this message
Old 12-19-2009, 08:36 PM   #5 (permalink)
murphdog's Avatar
murphdog wants to know where he is and how he got here
I got a Kent-Moore HD-44067 wrench from the dealer here for about $10, apparently they're more now. It has the cutout.
On my '07 motor, there's more room between the crank sensor and the filter so you don't need the cutout.
murphdog is offline   Reply With Quote Quick reply to this message
Old 12-19-2009, 09:21 PM   #6 (permalink)
Phemus
steveusmc's Avatar
steveusmc wants to know Dino or Syn?
I recommend spend that $20 for the wrench from the dealer for your $17 K - $30 K bike. Use the wrench, a long extension, and....don't forget to reconnect your voltage regulator plug.
Another thing that makes like much easier....install filter as "hand tight" as you can get it. Won't leak and it will come off much easier.
Assuming clean, dry filter and clean hands so you can actually crank down on it.
steveusmc is offline   Reply With Quote Quick reply to this message
Old 12-19-2009, 10:10 PM   #7 (permalink)
Premium octane member
TXCHOP's Avatar
You can dremel the cutout in the filter cap wrench easily. I also have a few different kinds of wrenches in the box like a cap wrench, strap wrench, and plier wrench, and 3 jaw style. Also some brand filters come off easier than others.
S&S T124
Old 12-20-2009, 12:14 AM   #8 (permalink)
Fred1369 is still riding a stock bike Fred1369 is still riding a stock bike
or, you can buy K&N oil filters. they come with a hex-head on the end so any crescent or box wrench will do. Plus, it's a K&N.
Fred1369 is offline   Reply With Quote Quick reply to this message
Old 12-20-2009, 12:16 AM   #9 (permalink)
maddogg4's Avatar
maddogg4 wants to know Dino or Syn?
strap wrench or an old thin leather belt is all I have ever used with ease. If you need any thing stronger than that you are putting the filter on too tight.
maddogg4 is offline   Reply With Quote Quick reply to this message
Old 12-20-2009, 04:49 AM   #10 (permalink)
MCE
MCE wants to know Dino or Syn?
I use K&N oil filters, I buy them 4 at a time at https://www.zanottimotor.com/shopping/partLookUp.html.
aftermarket part number is KN-171C
the C is for chrome, loose the C and you get a black one. although the black one didn't show on their site. I have an old steel strap type oil filter wrench that fits around the stock ones.
MCE is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 11:18 PM   #11 (permalink)
EasyWider's Avatar
EasyWider wants to know Dino or Syn?
I bought the one from Drag Specialties. Same as the HD filter wrench at about 1/2 the price.
EasyWider is offline   Reply With Quote Quick reply to this message
Old 12-28-2009, 12:57 AM   #12 (permalink)
repeat offender
Flyin Brian's Avatar
Flyin Brian wants to know Dino or Syn?
+1 on the cheap generic strap wrench. I don't use mine as much as HDWRENCH does, but I have had mine 10 years and it works perfect.
http://www.napaonline.com/Search/Mul...017_0006395283
2006 FLHXI Street Glide
This message has been sent to you using recycled electrons exclusively. Please do not discard them after use, send them along and help conserve these irreplaceable sub-atomic resources for future generations.
Flyin Brian is offline   Reply With Quote Quick reply to this message
Old 12-28-2009, 12:29 PM   #13 (permalink)
tdlowrider wants to know Dino or Syn?
I can usually get mine off by hand
tdlowrider is offline   Reply With Quote Quick reply to this message
Old 12-28-2009, 12:56 PM   #14 (permalink)
lowmileage's Avatar
lowmileage wants to know Dino or Syn?
Yesterday, I couldn't find my homemade cut-out wrench I made. Channelocks worked just fine. Only tightened the new one 1/2 turn from finger tight.
'04 Superglide, EFI, TFI, Stage 1, SE II mufflers
1975 Honda 750 K5 - Original owner.
Remembering my Dad, 1917-2003, who rode Harleys before it was fashionable.
lowmileage is offline   Reply With Quote Quick reply to this message
Old 12-28-2009, 12:59 PM   #15 (permalink)
DavHJ wants to know Dino or Syn?
This is the oil filter wrench that i like I think it works great.
http://www.eglidegoodies.com/id79.html
And this drip pan
http://www.cornwelltools.com/webcat/...son-Oil-Funnel
Dave
DavHJ is offline   Reply With Quote Quick reply to this message
