Bub Enterprises
Motorcycle.com Classifieds!CycleGear.comRRcycles.comFuel MotoMotorcycle-CommunicationAdvanstarMotorcycleShowsProCharger.comMBO EnterprisesCustom Dynamics
Old 10-21-2009, 05:00 PM   #1 (permalink)
heathsdyna is on a distinguished road
would like to put a beefy-er motor in 97 lowrider?????
Hi
i have a 97 low-rider dyna with a 80" evo, my question is what options do i have to get more power.what engines can i get or try to buy?, i dont have lots of money .im a 32yr old truck driver with bills,ive looked into head work and cams for my stock evo.what have you done to yours any help or ideas are a major help thanks
were i walk i walk alone , were i go i go alone.
heathsdyna is offline   Reply With Quote
Old 10-21-2009, 11:21 PM   #2 (permalink)
Fred1369's Avatar
Fred1369 will become famous soon enough
Getting it punched out to 88 inches, polish the heads, valve radius job, hot street cams with gear drive (you don't need racetrack cams), daytona twintec ignition, primary chain tensioner ( no extra power but it makes it a whole lot smoother), and 2-into-1 pipes. I assume you have already done something with the air filter. All this will cost less than 1/2 of what a new engine would cost.
Fred1369 is offline   Reply With Quote
Old 10-22-2009, 06:13 AM   #3 (permalink)
LADave is on a distinguished road
Mine's basically an 80-inch. Went .005" over to clean out the cylinders, installed an Andrews EV27 Cam, S&S "E" Carb, 2-into-1 pipe, Single-Fire ignition. Runs pretty strong.
Its in a 1987 FXR, will hang with most 88-inch Twinkies. Has out-run a few...
If you shop around (Craigslist, eBay, etc.) you can find some 100+ inch engines out there for close to the price of an 80-inch...
Everyone wants to go to heaven,
Nobody wants to go now...
1987 FXRS-SP
.005" over 80-Inch, Andrews EV27 Cam
S&S "E" Carb - Ultima Single Fire Ignition
Manley Stainless Steel Valves & Crower Springs
Ultima Single-Fire Ignition
2-into-1 pipe (might be an LSR)
LADave is offline   Reply With Quote
Old 10-22-2009, 06:56 AM   #4 (permalink)
my concern with that is the ultima , revtech motors are very decent priced but how reliable are they and parts were do i go for them.as my engine is right now im stock motor , dialed up carb , heavy breather and vance hines exhaust.would i need head-work if i just threw in a beefy cam====also as bike is now i keep up and accelerate better than a 88 but he pulls ahead when we at 140.
Old 10-22-2009, 11:14 AM   #5 (permalink)
mooooving out!
route66paul's Avatar
you would be better off having one of our sponsers build you engine. if you have money to buy a new revtech, you should have enough money to have a stroker built for you with you cases. You will have a better built motor and it should last longer also.
Whether or not you go to a stroker, many here would tell you that you are better off with stock cases. 80s can be built to run with TCs and to be dependable.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 10-22-2009, 12:55 PM   #6 (permalink)
lucille's Avatar
lucille is on a distinguished road
Dyna fun...
An easy, low cost mod....EV27, EV3, EV46 cam....torrington cam bearing of course.
Your 'stock' heads are worth getting done...there's lots of 'meat' in the stockers and they can be made to flow, and with a head shave, this will bump the CR a point.
Steel breather gear, and an ignition module with a faster curve-rev limit to 6000rpm.
You didn't say what your carb was?
This is a mild mod, but gives good 'seat of the pants' for the $.
It also will let your motor live a long time......Where in B.C.?
lucille is online now   Reply With Quote
Old 10-22-2009, 02:45 PM   #7 (permalink)
midnight sporty's Avatar
midnight sporty is on a distinguished road
now im sure bvbob will say im a cheerleader again. and ban me. but i will say hillside has had some oddly great luck with evo packages.. like lucille said. theres tons of meat in the stock evos to widdle away..
08 crossbones
hillside 107
woods tw8 cams
hillside stage 3 heads
s&s roller rockers
s&s adj pushrods
55 hpi throttle body
larger injectors
D&D fatcat-perf baffle
vp92t
hillside air filter
230 ccp
not one ounce of pinging
hillside cycle...
midnight sporty is offline   Reply With Quote
Old 10-24-2009, 02:13 AM   #8 (permalink)
Cheapdad is on a distinguished road
evo build
there are some good posts on the evo engine mods section...
My 1998 Lowrider started with Andrews 27, torrigton, Mikuni 42, lifters, adjustable push rods, single fire, cycle shack...dyno'd at something around 71 hp, 75 tq...a nice improvement over stock.
Second step was street port--really, just a mild head build and 5 angle valves, screaming eagle pistons, target 9.75:1 compression.
She REALLY woke up! I don't have a dyno yet, but a definite bump up. AND, my MPG mileage improved...when I don't "play" too much.
VERY nice power range, smooth, and pulls the mountains here in Idaho very well. I ride with a stock 96 inch street glide, and a 88 built to 96 inch Heritage...."roll on" races are fun....it's not me that is last--ever!
Cheapdad
Cheapdad
1998 Lowrider
80 inch, mikuni 42, Andrews 27, Cycle Shack
9.75 compression, SE pistons, street port
Cheapdad is offline   Reply With Quote
Old 10-24-2009, 10:35 PM   #9 (permalink)
lucille's Avatar
street fun....
Like Cheapdad said 'roll on races are fun'....
My FXR, at 575 lbs. dry, EV27, stage II heads, 9.6 cr, modified CV, ignition module, and modified exhaust/with crossover dynos 77hp and 86tq.......I like playing with 'twinkies'
