Heres the short answer, yes. With enough time, money and skill anything can be done. I just read an article where they put a 96 Sportster motor in a 72 Sportster frame. If that can be done there is no reason your bike can be swapped out.
I know for a fact that you want to go no newer than an 03 motor setup. Harley changed the frames for the Dynas in 04, then again in 06. 96 to 03 use a lot of the same body parts so the frames are probably pretty similar.
Let us all know what you find out. And be sure to post pictures!
later,
KrustyTC
